2 Pages V  1 2 >
> Seat Belt Interlock Relay, Late 74-76’ - how does it work?
post May 15 2025, 09:57 AM
For those of you that despise the seatbelt / starter interlock and the horrific screeching noise the seat belt buzzer makes - let me say I understand completely. As I’ve been playing with this on the bench my wife now hates the noise just as much as I do.
This thread is going to explain how it works and how to bench test it over the coming days.
Credit is owed to @JeffBowlsby , @Bdstone914 , and @Montreal914 for providing me with donor parts that will make this thread possible.
Eventually I will post the schematic of this ridiculous conglomeration of components. I hope to eventually put the circuit in LTSpice to help verify its theoretical operation. I make no warranty as to the accuracy of the schematic - this is just me satisfying my own curiosity.
If you have no interest in my personality defects that would lead me to take on this little project; ignore this thread.
If you have a late car with an in-op system and eventually want to get it working - this thread is for you.
Toward the end I’ll share some ideas on how to get rid of or to change that horrific buzzer noise.
post May 15 2025, 10:05 AM
My curiosity in this part is the result of the Haynes manual which only shows the interlock relay as a “black box” and makes little mention of how it actually works. This is in contrast to the simple Fasten Seat Belt light used in 72’ & 73’ that at least has a notional schematic but just lacks the actual component details.
Likewise neither Haynes nor the Factory manual make any effort to really explain how this thing is supposed to work. The end result being that most of these have been disconnected and bypassed over the years.
post May 15 2025, 10:06 AM
Let’s start with how this thing is supposed to work.
Here is the overview from the service and training manual that Jeff Bowlsby provided from his stash of technical documents.
Attached ImageAttached Image
ClayPerrine
post May 15 2025, 11:09 AM
While I am curious to know how it works, I am still going to rip it and all the associated wiring for it out of the car.
I NEVER drive without a seatbelt. Number 1, it is stupid not to wear a seat belt. And Number 2, I am so conditioned to putting on the seat belt that I feel like I forgot my pants if I don't wear it.
And nobody wants to see me without pants. (IMG:style_emoticons/default/w00t.gif)
post May 15 2025, 11:34 AM
QUOTE(ClayPerrine @ May 15 2025, 01:09 PM) *
Totally understand (IMG:style_emoticons/default/happy11.gif)
914werke
post May 15 2025, 11:44 AM
Old thread
post May 15 2025, 11:57 AM
So this is where things start to go astray.
I cannot duplicate the “logic” operation of the training information.
I have two different interlocks that appear to be functional. Neither seems to require that the seat cushion be loaded to enable the starter. I’ll detail this more later in the thread as it progresses.
Second, I have been unable to verify that there is a time aspect as referenced for a restart within 2 minutes +/- 1 minute.
There are 3 electrolytic capacitors in the circuit and it is possible that they are using a RC time constant to affect the circuit. I just haven’t been able to duplicate this and this is why I intend to put the circuit into LTSpice so I can better understand why this isn’t working as it is described by that training document. I am currently working on verify the capacitors. They are 50 years old and although they measure at their rated capacitance, they seem to leak a little more current than they should.
[5/16/25 update - I’ve replaced the 3 electrolytic’s in the best operational relay - still no change in being able to get a seat cushion dependency or a time dependency]
The one thing I haven’t been able to find is a 74’ -76’ owners manual to see how the operation is described there. If anyone cares to post that it would be appreciated.
From here on out I’ll be posting the actual results I’ve observed bench testing the two “functional” relays I have.
post May 15 2025, 11:59 AM
QUOTE(914werke @ May 15 2025, 01:44 PM) *
Any joker can cut it out (IMG:style_emoticons/default/happy11.gif)
rjames
post May 15 2025, 12:53 PM
I'm made of metal
Following
I've thought about trying to reconnect it my '75 (was disconnected by the PO) just to see if it still works. I could do without a buzzer, but I think it would be kind of cool in a '70s sort of way to have the fasten belts sign light up with weight on the seat.
Root_Werks
post May 15 2025, 01:06 PM
Village Idiot
QUOTE(rjames @ May 15 2025, 11:53 AM) *
Following
My 75' was already hacked up in a bad way. Wound up removing all the wires associated with the system including the ones up to the belt lock (replaced the stickers, why not?).
Would be sort of cool to have it functional. That old school 70's buzzer.
post May 15 2025, 02:47 PM
Let’s start with the Haynes / factory manual black box & current flow diagram. This is useful to explain the basic wiring and switch states.
The bench testing will be set up with the following color code:
Ground will be black.
12v power will be red
Switched grounds will be green
12v starter power to the solenoid is yellow
These are highlighted in the graphic below
Driver door only shown as switched ground in green
Door switches omitted - more on that later.
Power enters on pins: 15, 30, 85
Ground is pin 31
Yellow Pins “C” and 50 are the connections that are normally jumpers together when this system is disabled. The connection between these pins is normally completed inside the interlock relay when the seat belts have been fastened and the key is in the START position.
post May 15 2025, 02:59 PM
The PIN ID’s are clearly labeled on the interlock relay.
Here’s the basic power and ground Attached Image
post May 15 2025, 03:03 PM
The Fasten Seat Belt light is powered by 12v supplied to one side of the bulb
The light is turned on/off via switched ground coming from the interlock relay on pin “L”,
In the photo above you’ll notice that with no inputs from the seat cushions and no input from the seat belt latch switches - the Fasten Seat Belt (let’s abbreviate as FSB) light is not lit. The buzzer is not active.
This setup represents:
Key in ignition - 12v on pin 85
Ignition on - 12v on pin 15 and 30
Doors closed - no ground connection on pin 86
post May 15 2025, 03:39 PM
So let’s talk about the horrific buzzer
If a switched ground is addd to pin 86 representing an open door the buzzer will start screeching. This is shown in the video as the green switched ground wire contacting pin 86.
When the door is closed, the switched ground is removed from pin 86 and the buzzing related to the key in ignition is silenced.
The other way the buzzer can be silenced when the door is open is to remove the key from the ignition. When the key is removed, 12v power will be removed from pin 85. This is shown in the video as removal of the red 12v power from pin 85.
This is the schematic:
https://www.youtube.com/watch?v=XaIyrzDqc9A?si=LNyjKM6TgSI4igj
Note: disregard the yellow starter circuit - I color in my books like a kid and unfortunately that is on the page and not a digital edit (IMG:style_emoticons/default/rolleyes.gif)
fiacra
post May 15 2025, 04:51 PM
Person.Woman.Man.Camera.TV
QUOTE(Superhawk996 @ May 15 2025, 10:57 AM) *
Here you go. From my 1975 Owner's manual. Page 26 simply talks about seat position and how to properly deploy the seat belt and isn't really relevant.
rjames
post May 15 2025, 06:01 PM
I'm made of metal
F that buzzer. (IMG:style_emoticons/default/laugh.gif)
post May 15 2025, 06:38 PM
QUOTE(rjames @ May 15 2025, 08:01 PM) *
(IMG:style_emoticons/default/lol-2.gif) for sure!
I’ll have solutions for this later
More stuff coming. I don’t have time to post it all in one giant chunk.
Tomorrow I’ll cover the seat cushion and door switch behaviors. (IMG:style_emoticons/default/laugh.gif)
post May 15 2025, 06:52 PM
QUOTE(fiacra @ May 15 2025, 06:51 PM) *
Thank you !!
Was searching online and couldn’t find a copy - so sort of saying the same things as the training document.
I will try to layout how this is true at least in part via the schematic if not explicitly by the functionality and bench test of the interlock relay.
Artfrombama
post May 15 2025, 07:05 PM
Interesting, appreciate the research!
P. O. did the jumper modification but the buzzer still works on my car, I ignore it. I left all the hardware in as well as the seat sensors in case the next owner(s) want to restore the thing.
JeffBowlsby
post May 15 2025, 09:51 PM
This is awesome Phil! Chipping away at one of the last 914 mysteries. Following.
2 Pages V  1 2 >
- Lo-Fi Version Time is now: 1st June 2025 - 12:55 PM
