> 91462801120 wiper insulator
9146-racer
post May 14 2025, 01:59 AM
Hi All.
Does anyone know where in the uk I can buy one?
or failing that what are the dimensions ?
cheers
Ian
post May 14 2025, 06:14 AM
See https://914rubber.com/black-windshield-washer-squirter
9146-racer
post May 14 2025, 07:09 AM
QUOTE(jim_hoyland @ May 14 2025, 06:14 AM) *
Not the washer, I want the of centre insulator that bolts to the bulkhead and the wiper motor.
Luke M
post May 14 2025, 07:41 AM
sold here : https://914rubber.com/windshield-wiper-offset-isolator
post May 14 2025, 07:48 AM
Are two required ? or just one ?
sixaddict
post May 14 2025, 08:02 AM
Don’t consider myself “expert”…..but I disassembled one and have one currently….only one per rack based on that experience…$2 from what I am seeing.
mate914
post May 14 2025, 08:12 AM
Matt
QUOTE(9146-racer @ May 14 2025, 09:09 AM) *
I think its the same part used in other P cars. Rubber bushing with a stud on each end. Right? I did this same job about two years ago. Lots of vendors have them.
Matt
post May 14 2025, 12:35 PM
(IMG:style_emoticons/default/beer.gif)
Mikey914
post May 14 2025, 01:47 PM
The rubber man
QUOTE(mate914 @ May 14 2025, 07:12 AM) *
Matt
Wrong.
Lots of companies make isolators, but the correct part has an offset.
We make the one with the offset. The fuel pump mount ones are not and are inexpensive as they are commercially available. There is a reason we made these.
You can maybe flex one enough to get it in, but I'm sure you will have a premature failure as they aren't designed to hold an offset load with additional flexing.
https://914rubber.com/search/?q=offset+isolator
Gordon.Hewitt
post Aug 13 2025, 03:28 PM
Region Association: England
If you are still looking, I have a spare in the UK.
