> FS: 2258 type 4 stroker engine parts project up for sale, Project switched directions, selling these goodies
914Wes
post Apr 16 2025, 10:38 AM
I have most of the parts needed to build a nice 2258 (78mm stroke 96mm bore) type 4 engine. Listing these off the top of my head, may be missing a few parts from the list.
Early W/EA engine case with the reinforced area behind the jugs
unused DPR German 78mm counter weight stroker crank,
new German flywheel,
New 5.325 Chromoly 'H' Beam Connecting Rod Set, 22mm Pin, with ARP Bolts.
New Biral AA cylinders 96mm
New Entended billet pushrod tubes from CSP in Germany
New Bare AA 2.0 casting heads ready for machine work.
Dellorto 45 carbs off a 2270 but have been sitting now and would need a rebuild.
New CSP bellcrank carb linkage
New gasket set, and seals.
New oil cooler.
123 ignition with 3 Pin Permatune CDI box. 911 style ignition on a type 4.
New Webcam 86a with lifters + cam gear and all hardware.
Good used thermostat
NOS KS cam and crank bearings
new valve covers
all the little gaskets and hardware new or nos, flywheel bolts, bearing etc.
1.7 rocker arms with 911 swivel rockers
Im sure I have more I am forgetting at the moment.
Can pickup from Bruce Stones shop in Riverside. Can ship as well or I can have the parts dropped off to European Motorworks and built into an engine.
Will sell everything for $4000 as a black friday package.
914Wes
post Nov 27 2025, 08:19 AM
Type 4 Engine Package – Complete Parts List
Engine Case
• Early W/EA reinforced Type 4 case .............. $550
Crankshaft / Flywheel / Rods
• DPR 78mm German counterweighted stroker crank (unused) .............. $750
• New OEM German flywheel ....................................................... $300
• 5.325" Chromoly H-beam rod set w/ ARP bolts ........................ $280
Cylinders / Heads / Valve Train
• AA Biral 96mm cylinders (new) ............................................... $450
• AA 2.0 bare casting heads (pair, new) .................................... $650
• CSP extended billet pushrod tubes .......................................... $260
• 1.7 rocker arms w/ new 911 swivel adjusters ............................. $220
Induction
• Dellorto 45 DRLA carbs (used, need rebuild) ............................. $800
• CSP bellcrank carb linkage .................................................... $190
Ignition
• 123 Distributor (new) ............................................................... $300
• Permatune 3-pin CDI (new/working) ....................................... $600
Total ignition value ............................................................. $900
Camshaft & Internal
• Webcam 86A cam kit (cam, lifters, gear, hardware) .................. $750
• NOS KS cam bearings ................................................................ $120
• NOS KS crank bearings .............................................................. $120
Cooling & Misc
• New oil cooler ......................................................................... $90
• New gasket & seal set ................................................................ $75
• Good used thermostat .............................................................. $100
• New valve covers .................................................................... $50
• Hardware, flywheel bolts, misc fasteners ................................. $60
[HR]
Total Value: $7,225
IronHillRestorations
post Nov 27 2025, 09:53 AM
I. I. R. C.
This is a great deal! GLWTS Wes!
- Lo-Fi Version Time is now: 28th November 2025 - 01:58 PM
