> Fan Shroud, Are you supposed to be able to seperate it?
Vicious
post Apr 1 2025, 01:13 PM
My fan shroud in some spots looks like it's separating. I'd like to fully seperate it and get it cleaned up and powder coated/ painted in and out. I don't see any fasteners holding it together though
Geezer914
post Apr 1 2025, 01:30 PM
Geezer914
Should be screws holding it together.
post Apr 1 2025, 02:15 PM
QUOTE(Geezer914 @ Apr 1 2025, 01:30 PM) *
also a couple steel dowels, often get stuck there
post Apr 1 2025, 02:19 PM
It's balanced so make some witness marks so it goes together the same way.
Vicious
post Apr 1 2025, 03:14 PM
QUOTE(Geezer914 @ Apr 1 2025, 02:30 PM) *
There was in fact no screws holding the shroud together. One of many things I've found that show me that the shop the previous owner had put this thing together were idiots. The alternator was the only thing holding this thing together. I will need to source some replacement screws while it's at the powder coater
brant
post Apr 1 2025, 04:07 PM
maybe balancing it when you reassemble.
it rotates pretty high speed at high RPM
worth doing.
Vicious
post Apr 1 2025, 05:32 PM
QUOTE(brant @ Apr 1 2025, 05:07 PM) *
worth doing.
I was wondering about the balancing comment above. Now I'm realizing i must be using the wrong verbiage. This is the piece I'm talking about. The two halves were not fastened together and after removing the alternator were able to be separated. If anyone knows what the correct size fastener is I'd be very grateful.
Ron914
post Apr 1 2025, 05:45 PM
QUOTE(Vicious @ Apr 1 2025, 06:32 PM) *
worth doing.
I was wondering about the comments on this ,only the fan wheel itself turns certainly the shroud doesn't rotate .
Ron914
post Apr 1 2025, 05:47 PM
QUOTE(Ron914 @ Apr 1 2025, 06:45 PM) *
worth doing.
While working on my motor during reassembly I tried to split the halves of the shroud but it didn't bug so I decided leave it alone before I break it.
bkrantz
post Apr 1 2025, 07:53 PM
QUOTE(Vicious @ Apr 1 2025, 05:32 PM) *
worth doing.
Off the top of my head, it uses a couple of different thread sizes and lengths. I replaced the stock bolts with stainless Allen heads.
post Apr 1 2025, 08:00 PM
QUOTE(Vicious @ Apr 1 2025, 02:14 PM) *
Look up the sizes in PET. Several 6mm by about 30mm and a few 8mm hex bolts
Vicious
post Apr 1 2025, 08:12 PM
QUOTE(bdstone914 @ Apr 1 2025, 09:00 PM) *
I'm sorry but still A LOT i don't know...what is PET?
JeffBowlsby
post Apr 1 2025, 10:35 PM
Here is a copy:
https://bowlsby.net/914/Classic/zTN_Man01C.pdf
Mikey914
post Apr 1 2025, 11:38 PM
The rubber man
I've got them, hit me up and I'll drop them in the mail.
brant
post Apr 2 2025, 05:47 AM
My mistake
Misunderstood
Vicious
post Apr 2 2025, 05:58 AM
QUOTE(Mikey914 @ Apr 2 2025, 12:38 AM) *
My hero
post Apr 2 2025, 07:15 AM
QUOTE(mepstein @ Apr 1 2025, 04:19 PM) *
(IMG:style_emoticons/default/screwy.gif)
mgphoto
post Apr 2 2025, 05:54 PM
Fan needs to be balanced, if you take it apart, not the shroud, I needed to take mine apart to clean the grease out of it before power coating. A bit tough to separate but it can be done.
- Lo-Fi Version Time is now: 2nd April 2025 - 10:30 PM
