2 Pages V  1 2 >
> So thats what a 1.8L muff looks like on 2.0 HEs, Didn't think it would even fit on the HEs.
JeffBowlsby
post Mar 31 2025, 04:01 PM
What is seen cannot be unseen. (IMG:style_emoticons/default/confused24.gif)
https://www.beverlyhillscarclub.com/1974-po...ter-c-17295.htm
JeffBowlsby
post Mar 31 2025, 04:27 PM
The peanut gallery can decide if this is even drivable as is from this underbody photo...geez...
NARP74
post Mar 31 2025, 05:01 PM
There is a reason the factory did certain things. Other reasons it might be undrivable, can't see a shift rod, no clutch cable, and no speedo cable. Must be a work in progress.
Got to keep up with those design changes.
Maltese Falcon
post Mar 31 2025, 05:11 PM
License plate frame speaks volumes.
JamesM
post Mar 31 2025, 07:22 PM
QUOTE(JeffBowlsby @ Mar 31 2025, 02:01 PM) *
In factory form it shouldn't, flanges have different bolt locations.
(IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/sawzall-smiley.gif)
Guessing they drilled the HEs or replaced the flanges completely as the factory 1.7 muffler has studs.
bkrantz
post Mar 31 2025, 09:01 PM
That 914 has far too much intact sheet metal for BHCC. (IMG:style_emoticons/default/screwy.gif)
KELTY360
post Mar 31 2025, 11:25 PM
914 Neferati
QUOTE(Maltese Falcon @ Mar 31 2025, 04:11 PM) *
Reminds me of a W.C. Fields quote, "I wouldn't to be a member of a club that would want me to join." (IMG:style_emoticons/default/evilgrin.gif)
Krieger
post Mar 31 2025, 11:30 PM
KYB shocks are always a good indicator of a quality build! (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/barf.gif)
post Apr 1 2025, 05:47 AM
@JeffBowlsby
' date='Mar 31 2025, 03:27 PM' post='3198984']
[/quote]
I thinkbthar muffler is a 1974 1 8 with the bolt on exhaust tip. But still how?
I once went to a muffler shop called M & F Muffler. They told me it stood for "make it fit"
They did.
I think they welded the heat exchanger to the muffler.sinlet flange. Note the open hole in the HE flange. Kustom fit. A BHCC concour car.
Gaskets? We don't need no stinken gaskets.
post Apr 1 2025, 06:07 AM
Looks like they did the kustom muffler fits on a Creamsicle.
Oh the huge manatee!!!Attached Image
post Apr 1 2025, 06:23 AM
QUOTE(JeffBowlsby @ Mar 31 2025, 03:27 PM) *
I think i will call them and ask if I can rest drive it. I should drive if I start in first gera and don't bother with that silly clutch pedal. I have done the before when I broke a clutch cable
JeffBowlsby
post Apr 1 2025, 09:10 AM
If thats true I am without words. Those SS HEs look new-ish...better to not have done anything rather than damage good parts.
JeffBowlsby
post Apr 1 2025, 09:14 AM
A knowledgeable buyer should look this car over very carefully. It may not be a complete car, just a tub with some mismatched parts more or less attached to it.
I noticed the write up on it is copy pasted from their previous CS, which had brown interior and dual mirrors. This car does has neither but it does have the 75-76 door panels and who know what else. The dash gauges look nice.
They do mention it is a non-running project car.
brant
post Apr 1 2025, 09:19 AM
imagine the torque that must be twisting the head studs to get that muffler lined up.
JeffBowlsby
post Apr 1 2025, 09:23 AM
That was what is puzzling. The 1.7/1.8 HE ends/muffler mounts are ~1.5 inches wider than the 2.0L HE ends/muffler mounts.
(IMG:style_emoticons/default/smash.gif)
Garland
post Apr 1 2025, 09:46 AM
Restoration Fanatic
Wannabe trail dragger!
Garland
post Apr 1 2025, 09:47 AM
Restoration Fanatic
(IMG:style_emoticons/default/welder.gif) Wannabe trail dragger!
sportlicherFahrer
post Apr 1 2025, 10:09 AM
Nothing to see here.
Best shifting 914 on the road with the new and improved WiFi shifter assembly! (IMG:style_emoticons/default/blink.gif)
post Apr 1 2025, 10:17 AM
@JeffBowlsby
date='Apr 1 2025, 08:23 AM' post='3199116']
[/quote]
Easy. Center the muffler over the heat exchangers. Ignore that nothing lines up.
Weld muffler to heat exchangers.
Wal la! Done.
Zoom in on the pictures and you can see the heat exchanger flanges extending inward beyond the muffler flanges.
post Apr 1 2025, 10:20 AM
QUOTE(brant @ Apr 1 2025, 08:19 AM) *
Zoom in on the muffler to heat exchanger flange. They welded them together. Exit holes on the HEs will cover half of the muffler inlet holes. And was needs gaskets.
2 Pages V  1 2 >
- Lo-Fi Version Time is now: 2nd April 2025 - 10:31 PM
