2 Pages V  1 2 >
> Why do replacement CV joint boots have six holes instead of the four like original
TonyA
post Feb 4 2024, 10:10 AM
Nachmal
Why do replacement CV joint boots have six holes instead of the four like original.
Is it so the grease has a spot to leak out in a few years and splash all over. I am getting pissed at aftermarket stuff not made right and I find this out six months after purchasing. Why are there six holes. In my quest for originality I WANT IT RIGHT (I know most don't give a crap) but I do! My rant for today thanks for watching.
post Feb 4 2024, 10:26 AM
The 914 boot is the same size as the stock VW Bug boot. You wound think it should be a simple program NOT to drill the 2 holes. Manufacturers don't see a market.
mate914
post Feb 4 2024, 10:31 AM
Matt
QUOTE(TonyA @ Feb 4 2024, 11:10 AM) *
I hear ya, but cheer up. Who else has the first LE car and was a foot model?
Maybe take a pic so we can see.... of the boot, not your foot..
Matt
burton73
post Feb 4 2024, 10:47 AM
Senior member, and old dude
This is a picture from web. How would a person fix that?
Bob B
post Feb 4 2024, 11:48 AM
A reproduction is by definition not original
TonyA
post Feb 4 2024, 12:23 PM
Nachmal
Excuse me I mean original looking.
TonyA
post Feb 4 2024, 12:25 PM
Nachmal
QUOTE(mate914 @ Feb 4 2024, 11:31 AM) *
Matt
(IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) You made me laugh buddy.
MartyYeoman
post Feb 4 2024, 12:55 PM
Add a little piece of HVAC foil sealing tape to the underside of the flange over the unwanted openings. May not look original but should stop the leak concern.
fixer34
post Feb 4 2024, 01:10 PM
You got me wondering since it has been a LONG time that I did anything with CV joints, including even looking at them.
Are the 4 hole boots every 90 degrees, or every 60 (like a 6 hole), just 2 of them aren't punched/drilled out?
Aren't the boots the same for a -4 and -6? The -6 uses 6 bolts I believe, so it would seem to make sense to make something that fits both. Easier to plug a hole (tape or silicon caulk) than make one.
post Feb 4 2024, 01:12 PM
Thinking a plastic plug would accomplish closing the hole. Even a metal claw plug might work too.
fixer34
post Feb 4 2024, 04:39 PM
QUOTE(914Sixer @ Feb 4 2024, 01:12 PM) *
But isn't the metal cover on the boot supposed to be tight against the CV joint since it holds it in place? Either style of plug wouldn't let it seat properly.
pek771
post Feb 4 2024, 09:14 PM
The diameter of the boot is larger than the CV joint.. Add that to the list of concerns.
bkrantz
post Feb 4 2024, 09:26 PM
QUOTE(pek771 @ Feb 4 2024, 09:14 PM) *
That bothered me more than the extra holes.
post Feb 5 2024, 07:33 AM
So, what is the best solution when replacing ?
pek771
post Feb 5 2024, 07:52 AM
I’m going to put a bead of silicone around the perimeter of the joint, and hope for the best. I think the spinning CV will shoot out some grease. Because new CV have different diameters at either end, I don’t think a gasket will help..
DRPHIL914
post Feb 5 2024, 07:54 AM
Dr. Phil
Why can't someone make a correct design reproduction??
i found a set of OEM NOS ones that i installed last year when i had to pull the transmission to do the RMS seal , so no more flinging grease around! Cant remember what world member i bought them from but i am glad i grabbed them.
Phil
post Feb 5 2024, 09:07 AM
These are the woes of owning a 50 year old car in a small market. Just yesterday I was complaining, to myself in the garage, about some aftermarket deviation and realized I was lucky to have something vs nothing. Those holes can be welded shut then sanded or milled. (IMG:style_emoticons/default/beerchug.gif)
MikeK
post Feb 5 2024, 09:31 AM
Pardon my ignorance, but which six holes are you referring to? The holes for the CV bolts? Do 914's use four holes to mount?
DRPHIL914
post Feb 5 2024, 09:54 AM
Dr. Phil
QUOTE(MikeK @ Feb 5 2024, 10:31 AM) *
yes, 914's have 4 CV bolts , 2 pair, one pair on opposing side from one another. so that leaves 2 holes open if you use the EMPI ones.
VaccaRabite
post Feb 5 2024, 11:50 AM
En Garde!
Because its a Beetle part that EMPI is selling to 914 owners.
Same difference with the Beetle CVs that are now appearing on 914s. Same size, same hole spacing, but for some reason the 914 part uses 2 roll pins and 4 bolts instead of 6 bolts.
Zach
2 Pages V  1 2 >
- Lo-Fi Version Time is now: 12th May 2026 - 02:34 PM
