> Rear Sway bar install, Trying to figure out how everything goes together
roundtwo
post Jun 13 2021, 06:48 PM
Trying to get prepped for all my welding needs. Id like to Pre-fit the rear sway bar so I can determine exactly we’re to mount the bushing mount backing plates. I want to be sure they’re perpendicular to the sway bar in just the right spot
1. See first pick. Do I install the bushings in the drop links first and then install the ball ends? Or, do I install the ball cups on the balls and then have them pressed into the drop links? Any tips on how to get these hard bushings into the drop links?
2. Do I simply replace the new shock base metal rod labeled #1 with #2. See second pic
I’ve read the rear sway bar mounts instructions on the Pelican Parts web site. Very helpful- He just doesn’t cover the actual sway bar assembly. Bar is 16mm. Installing on a 1970.
Many thanks.
roundtwo
post Jun 13 2021, 06:50 PM
Adding sway bar on this build
ClayPerrine
post Jun 13 2021, 07:07 PM
The big bolt with the ball end replaces the lower shock mount bolt.
The drop links need the bushings inserted with one facing each way.
The bushings fit over the bar and the bar bolts to the sway bar plates under the back end. If the car didn't come from the factory with a sway bar, then the plates won't be there and have to be welded onto the chassis.
https://914rubber.com/914ltd-early-rear-swa...unt-bracket-set
(IMG:http://www.914world.com/bbs2/uploads_offsite/cdna3.zoeysite.com-1143-1623632826.1.jpg)
Not my car....
(IMG:http://www.914world.com/bbs2/uploads/post-10825-1563835013.jpg)
Check and see if you have the brackets. If not, just order a pair and get them welded on.
Clay
bkrantz
post Jun 13 2021, 07:38 PM
I put the bushings into the drop links first (used my hydraulic press), and then squeezed the links onto the trailing arms and sway bars, with a large clamp.
barefoot
post Jun 14 2021, 11:12 AM
QUOTE(bkrantz @ Jun 13 2021, 09:38 PM) *
Soak the bushings in boiling water then they go in easy
ClayPerrine
post Jun 14 2021, 12:21 PM
QUOTE(bkrantz @ Jun 13 2021, 08:38 PM) *
I just use a huge pair of channel locks to push the links onto the balls.
Clay
NARP74
post Jun 14 2021, 12:41 PM
I just went through this, mine had the mounting brackets which made it easier. I did everything on the car which made it harder. Do as much on the bench as possible. I used boiling water and then a little liquid soap and pressed them on. I removed the muffler to give me as much room as possible. Good luck...
roundtwo
post Jun 14 2021, 07:39 PM
Appreciate all the secrets!
Able to get in the shock mounts in easily. Have the plates/ backing plates on the bench after locating the destination pretty darn close on the sheet metal. That’s where the fun ended. Trying to press in the bushings was a disaster. Even with preheating the bushings, Lots of slippery stuff on the press the bushings kept mushrooming, distorting in shape wanting to crease on themselves. I Tried putting the perfect size socket in the balm cup to keep its shape during pressing. A no go!
post Jun 14 2021, 08:55 PM
Do like Clay said. A giant pair of channel locks and it helps to lube the metal ball ends. I used glycerin. I didn't need to heat them in water but it won't hurt if you do. (IMG:style_emoticons/default/beerchug.gif)
roundtwo
post Jun 14 2021, 10:43 PM
QUOTE(76-914 @ Jun 14 2021, 07:55 PM) *
I haven't made it that far. My hurdle is getting the cup bushings into the drop links. Good to know when I make it to the next step. Thanks y'all , Todd
LefthandRev
post Dec 22 2021, 03:58 PM
I used a heat gun, a dull flat head screwdriver, and a bench vice to get them started.
Open-side of the bushing first. Hold the heat gun, warm up the bushing. No higher than 200F, or you start to bubble the silicone. Push the lip through the ring and work it in slowly until about 90% (or all if you can manage) is started through the ring.
Pull the drop-arm out of the vice and with luck, the bushing will not pop off. Now, put the bushing into the vice along the thin portion and tighten it down. Using your screwdriver, inside it into the bushing and pull the lip of the bushing outward through the ring of the arm until it's fully seated.
Rinse, wash, repeat, curse, repeat, curse, repeat, curse...
914werke
post Dec 22 2021, 04:53 PM
QUOTE(76-914 @ Jun 14 2021, 06:55 PM) *
Good Call!
Its worth repeating, use of a bit of lube is helpful but do not use a petroleum based grease (I see this too often) Glycerin or plain 'ol dish soap will do the trick!
TRP
post Oct 18 2025, 11:19 PM
QUOTE(LefthandRev @ Dec 22 2021, 02:58 PM) *
This is a pretty old thread, but this worked like a charm. Thank you!
Ted
post Oct 19 2025, 12:08 AM
QUOTE(TRP @ Oct 18 2025, 11:19 PM) *
Ted
you wont regret a front and rear sway bar install on your 1.8 if thats what you have done. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beerchug.gif) grins from ear to ear. after all its a 1.8 and going around corners insanely flat is just about it --------if you know what i mean -------but its grins and grins and more grins. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif)
i have a 1.8 with the factory sway bars original. the first owner knew what he (or was it she?) was doing when they ticked the box on a base spec 74 1.8. that and the obscure but very practical storage box. who needs a console with all those guages. they just make you worry you are about to blow the engine up or cause the fan belt to flick off. and time, well you got a wrist watch for worrying about that. but you got to have somewhere to chuck your cigs or your hand bag. (IMG:style_emoticons/default/biggrin.gif) seriously the original owners on mine sure had taste in spades ticking that one "performance" box.
TRP
post Oct 19 2025, 09:12 PM
Today I wrapped up the rear sway bar today. This week I will finish the front swaybar install. Should be awesome. (IMG:style_emoticons/default/smile.gif)
TonyA
post Jul 28 2026, 03:58 PM
Nachmal
I used a pair of cabinet clamps from harbor freight and some glycerin and heated in hot water. popped right on. The shock bolt should be real bright and shiny.
porschetub
post Jul 28 2026, 06:01 PM
QUOTE(TonyA @ Jul 29 2026, 09:58 AM) *
Good comments ,my new rebushed drop links were already fitted into the swaybar when I got the roller from the PO, the big clamp worked a treat for pressing the lower on ,bit of liquid soap ,took a fair clamp pressure and it popped in ...job done ,cheers.
1 Members: Rusty_Rivets
- Lo-Fi Version Time is now: 28th July 2026 - 08:15 PM
