Proper Torsion bar install and adjustment, how to install and adjust the torsion bars on the front suspension |
ri914 |
Sep 20 2020, 10:00 AM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
Hello 914'ers
I need to adjust and calibrate my front suspension. I installed the new torsion bars while the car was on the lift and it now looks like it could chase a ford raptor through the woods. 1: Is there a procedure for installing these and what angle the a-arm should be at? 2: Should they be done at ride height and then adjusted by the torsion bar adjustment bolt ? thank you ben |
brant |
Sep 20 2020, 10:39 AM
914 Wizard Group: Members Posts: 11,603 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Index them to get the range of ride height you want
Then fine tune on corner balance scales |
914Sixer |
Sep 20 2020, 11:20 AM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Bars have to be indexed before installation. Most repair manuals should cover this. Adjusters are just used for minor up or down of 10-20 mm.
jim_hoyland |
Sep 20 2020, 11:38 AM
Get that VIN ? Group: Members Posts: 9,256 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
How does the indexing go if the caris up on the lift ?
rhodyguy |
Sep 20 2020, 12:52 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,055 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Look at the camber of the rear wheel. Roll your car back and forth a bit to settle the suspension.
mlindner |
Sep 20 2020, 01:52 PM
Senior Member Group: Members Posts: 1,509 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Ri914, your pictures shows how far off it is. With car weight on suspension that front A-arm should be horizontal as a good start point. If you have purchased stiffer bars you might need to index them on the lift raising the front suspension with like a transmission jack before torsion bar is set. Mark
ri914 |
Sep 20 2020, 08:45 PM
Ri914, your pictures shows how far off it is. With car weight on suspension that front A-arm should be horizontal as a good start point. If you have purchased stiffer bars you might need to index them on the lift raising the front suspension with like a transmission jack before torsion bar is set. Mark Great info everyone! Mark. Thanks for the explanation. I knew they had to be way off. Fingers crossed I don't have to roll the fenders. |
Lo-Fi Version | Time is now: 19th April 2024 - 05:54 PM |
