1st and reverse gears grinding |
JFG |
Sep 20 2020, 12:50 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
I'm unable to get into first gear without forcing it in unless the car has a little momentum. Reverse selection is a hell of a grind to get in also. 2nd to 5th are as smooth as silk.
All of the slector bushings were new just 2 years ago. Same for the clutch which has done less than 2000 miles. Any tips on what to look for? |
ri914 |
Sep 20 2020, 03:21 AM
Member Group: Members Posts: 102 Joined: 13-August 20 From: rhode island Member No.: 24,593 Region Association: North East States |
I'm unable to get into first gear without forcing it in unless the car has a little momentum. Reverse selection is a hell of a grind to get in also. 2nd to 5th are as smooth as silk. All of the slector bushings were new just 2 years ago. Same for the clutch which has done less than 2000 miles. Any tips on what to look for? There are a few youtube channels that really get into the workings and how to repair and fix the oem transmissions. I don't know why I watch all of them as I have a 6spd, but the precision and knowledge of these mechanics and there passion for originality is awesome. I would suggest maybe reaching out to this guy. Perhaps he is a member here? |
GregAmy |
Sep 20 2020, 09:14 AM
Advanced Member Group: Members Posts: 2,264 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
I'd suggest starting with verifying clutch adjustment.
Bleyseng |
Sep 20 2020, 09:35 AM
Aircooled Baby! Group: Members Posts: 13,034 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I'd suggest starting with verifying clutch adjustment. Yep, too often it's that and has been out of adjustment for a long time grinding off the dogteeth which is part of the grinding. Tighten it up and get it just so the throwout bearing isn't just touching the clutch plate. A old clutch cable too with lots of stretch in it also makes it hard to have a smooth gear shifting into 1st/Rev. |
bobboinski |
Sep 20 2020, 10:06 AM
Member Group: Members Posts: 197 Joined: 23-April 16 From: Petaluma Member No.: 19,929 Region Association: Northern California |
I also think grinding into reverse is clutch not fully releasing.
rjames |
Sep 20 2020, 11:30 AM
I'm made of metal Group: Members Posts: 3,911 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I also think grinding into reverse is clutch not fully releasing. (IMG:style_emoticons/default/agree.gif) |
type47fan |
Sep 20 2020, 11:37 AM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
Also, check for a possible clutch cable tube detachment in the tunnel.
Lo-Fi Version | Time is now: 20th April 2024 - 04:36 AM |
