Torque on PMB wheel studs, Found different answers using search |
andrewck |
Sep 19 2020, 08:29 AM
Newbie Group: Members Posts: 48 Joined: 5-July 20 From: Denver Member No.: 24,461 Region Association: Rocky Mountains |
Installing wheel studs into my 5 lug conversion hubs. It looks like torque values are 94 ft/lb? Could somebody confirm? I am using red Loctite as well so imagine as long as Loctite is on there and stud is snug, I should be ok.
Mark Henry |
Sep 19 2020, 08:39 AM
94 lbs is fine, DON'T use locktite, use a torque wrench. Re-check after your first drive.
If your rims have been painted the paint in the nut seats can be an issue, I torque all the nuts then loosen them off and blow out any paint chips with air, re-torque and check them several times over the next few drives. Edit, re-read your post, studs into hubs, yes red locktite, they don't need any torque IIRC. 94lbs is for the nut (rim to hub) torque. |
mepstein |
Sep 19 2020, 08:43 AM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I thought Eric recommended red lock tight as well but I'm not 100%. Call PMB and ask.
wysri9 |
Sep 19 2020, 11:36 PM
Member Group: Members Posts: 199 Joined: 23-August 13 From: Aberdeen, Scotland Member No.: 16,291 Region Association: England |
Another related question - what is the brains trust view on e.g. copper slip on studs/nuts? I'll have to have a good look later to see if Eric used Red Locktite when he installed the studs in my 5 bolt hubs (IMG:style_emoticons/default/smile.gif)
mepstein |
Sep 20 2020, 05:59 AM
Another related question - what is the brains trust view on e.g. copper slip on studs/nuts? I'll have to have a good look later to see if Eric used Red Locktite when he installed the studs in my 5 bolt hubs (IMG:style_emoticons/default/smile.gif) By copper slip I'm guessing anti-sieze? I use some but people seem so have different views. |
90quattrocoupe |
Sep 20 2020, 06:37 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
I have been using copper or nickel slip(Anti-Seize) on every lug bolt on every VAG car I have had over the last 50 years. Ten VAG cars. Never had one come off.
I use this stuff on every bolt/nut on all parts that come in contact with water or bolt into aluminum. I haven't had a piece fall off my car yet. I do track days with my Audi CQ and never had a problem. I use it on ball joints, tie rod ends, sway bar ends, etc. I use it between the hub and the rotors. Let's just say I use a lot of it. Greg W. |
VaccaRabite |
Sep 21 2020, 12:59 PM
En Garde! Group: Admin Posts: 13,425 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I use copper anti-seize on almost everything, including lug bolts.
I do not recall using it on the studs when I turned them in, but I probably did because I use it on everything. Zach |
Lo-Fi Version | Time is now: 26th April 2024 - 08:00 AM |
