Tis the Season for HOT START trouble, It CRANKS great - just will not fire |
ctc911ctc |
Jun 4 2020, 08:20 PM
Senior Member Group: Members Posts: 885 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
All,
Lots of threads about FORD relays (really?, would not any starter relay work) but this trouble is different. In the manual, it says to hold the accelerator pedal to the floor when starting a DJet, so I tried this. I would like to FIX this so I can start when the car is hot like a normal car (yea, I know it is not a normal car), has anyone made a modification to the instrumentation to fix this issue? Perhaps CHT modification? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) |
thelogo |
Jun 4 2020, 08:29 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Hot start or djet components ( acting cranky )
Not impossible but any djet issue very hard to find let alone fix ..... |
theer |
Jun 4 2020, 08:49 PM
Senior Member Group: Members Posts: 675 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Just to be clear- the Ford relay solution is for the starter not cranking when hot problem. As you say, this is different.
The next place to look is vapor lock. The early cars had the fuel pump in the engine compartment, where it would heat soak. Moving the pump to the front (as the factory did in later cars) usually solves that problem. If you’ve done that, then you’re left to figure out which component of the FI is being cranky. Others will have to chime in on that... I’ve had carbs since the 80’s (and I moved the fuel pump up front). My problem is more with cold starts in the spring and fall! Good luck. |
rjames |
Jun 4 2020, 09:33 PM
I'm made of metal Group: Members Posts: 3,876 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Hot start or djet components ( acting cranky ) Not impossible but any djet issue very hard to find let alone fix ..... (IMG:style_emoticons/default/rolleyes.gif) |
BeatNavy |
Jun 5 2020, 06:18 AM
Certified Professional Scapegoat Group: Members Posts: 2,921 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Other than actual vapor lock which I've never experienced (my pump is on the lower firewall), but from a D-Jet perspective Brad. Anders posted something here a couple of years ago where he surmised the issue is that the car is excessively lean during a hot restart. He was playing with the idea of using a variable resistor on the CHT that you could control from the cabin. I can't seem to find that thread jsut now.
In my case the issue was usually that the car was somewhat difficult to start and I had to feather the throttle for about 30 seconds before the idle would stabilize. What really helped me at least from the starting standpoint was using the hi-torque starter of all things. |
ctc911ctc |
Jun 5 2020, 07:13 AM
I will reach to Mr. Anders (Mr. Djet) and see what he recommends.
Will close out this thread with some discovery. ASAP Thank you CTC911CTC Other than actual vapor lock which I've never experienced (my pump is on the lower firewall), but from a D-Jet perspective Brad. Anders posted something here a couple of years ago where he surmised the issue is that the car is excessively lean during a hot restart. He was playing with the idea of using a variable resistor on the CHT that you could control from the cabin. I can't seem to find that thread jsut now. In my case the issue was usually that the car was somewhat difficult to start and I had to feather the throttle for about 30 seconds before the idle would stabilize. What really helped me at least from the starting standpoint was using the hi-torque starter of all things. |
76-914 |
Jun 5 2020, 08:52 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,455 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Does it seem that it wants to catch if you release the key quickly (from the start to on position) when trying to start it? If so, your switch is broken. Also, check the voltage at your coil when cranking to see if you have 12v.
ctc911ctc |
Jun 5 2020, 07:49 PM
BeatNavy |
Jun 6 2020, 04:38 AM
This is the thread I was thinking of originally: http://www.914world.com/bbs2/index.php?showtopic=298261 |
Lo-Fi Version | Time is now: 29th March 2024 - 04:18 AM |
