914 rust repair, we get into this every day |
dr914@autoatlanta.com |
Jun 3 2020, 12:37 PM
914 Guru Group: Members Posts: 7,817 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
bkrantz |
Jun 3 2020, 09:37 PM
914 Guru Group: Members Posts: 7,735 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
George, that reminds me. Do you (or others) know what the stock heat tubes are made of?
Jun 4 2020, 08:37 AM
Jun 4 2020, 09:29 AM
bretth |
Jun 4 2020, 03:33 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
How do you keep the paper tubes from going on fire when welding the panel back on?
Bartlett 914 |
Jun 4 2020, 04:05 PM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
George. Can you show us a better picture of your bracing?
malcolm2 |
Jun 4 2020, 06:43 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
914werke |
Jun 5 2020, 01:53 AM
"I got blisters on me fingers" Group: Members Posts: 10,004 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I have never seen one, but I don't think they are paper. They are. The are the same foil backed corrugated paper tube material that is used in the cowl just a larger size with a smaller one fit inside it & as George said FG packed into the void. The whole affair is then held together by plastic end caps glued on. I have several FS. Same unit used in both 911 & 914. |
Jun 5 2020, 08:21 AM
Bartlett 914 |
Jun 10 2020, 08:05 AM
That is a lot of bracing. Thanks for posting George
luft |
Jun 18 2020, 11:28 PM
Newbie Group: Members Posts: 19 Joined: 11-January 16 From: Carefree AZ Member No.: 19,551 Region Association: None |
Tman914 |
Jun 19 2020, 11:29 AM
Member Group: Members Posts: 136 Joined: 9-December 04 From: "Livermore, Ca" Member No.: 3,247 Region Association: Central California |
George
On your bracing i see the lower bar mounting but the upper one is mounted where upper door hinged goes and then it disappears ? Thank tman914 |
Lo-Fi Version | Time is now: 26th April 2024 - 08:41 AM |
