Shortening Shift Lever |
Ansbacher |
Apr 8 2020, 10:48 AM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Will removing just 1 CM from the top of the shifter lever be noticeable when shifting? In other words, will it be harder to shift and require more effort? I am trying to utilize a custom shift knob which does not cover as much of the shifter shaft as the stock knob, revealing some flaws in the chrome. If I cut off 1 CM from the top of the shaft that bad part will be hidden under the new knob. Thanks.
Ansbacher |
oakdalecurtis |
Apr 8 2020, 11:19 AM
Oakdalecurtis Group: Members Posts: 1,323 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Hey Ans,
The shifter is a lever, as you stated. If we use simple math, let's say the shift lever is approximately 25 cm long as measured from the pivot point in the console. If you were to remove 1 cm, you would increase the required original shifter force, as measured at your hand, by 1/25 of whatever it was. In other words, inconsequential...... (IMG:style_emoticons/default/beerchug.gif) |
Ansbacher |
Apr 8 2020, 11:51 AM
Sounds logical Oakdale. Thanks. I may not have to cut it anyway, as I found a nice piece of rubber tubing that fits perfect below the knob and mates just right so it looks like part of the knob. Hides the chrome flaws.
Ansbacher |
windforfun |
Apr 8 2020, 03:38 PM
Senior Member Group: Members Posts: 1,775 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
torque = force X distance
Cairo94507 |
Apr 8 2020, 04:28 PM
Michael Group: Members Posts: 9,708 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
1 cm equals .39 of an inch. So I doubt you would really notice the difference.
Lo-Fi Version | Time is now: 23rd April 2024 - 01:53 PM |
