GB Hardware+ - Visor screws + front turn signal lens screws+, Ends Tomorrow 4.30.20 e if you want Plus something you may not have known about the signal cover screws |
Mikey914 |
Apr 8 2020, 02:43 AM
First off thanks to those of you that bought my visors. we made some visor screws that are currently of for nickel plating as I write this. This will be ready this next week.
We did also make the front turn signal lens screws. These are an unusual animal in that they are not quite what the appear to be. Did you even notice that they strip out a little easier than most screws? We believe this to be a design feature. Most screws are steel either stainless or carbon with plating on them. If you have an original you will notice it sounds a little different if you drop it on concrete. The reason is that they are made out of aluminum. This is because they were designed to strip out. Yes intended to strip. If they were over tightened. Mechanically you could put much more pressure than you would want onto the lenses with a steel screw. Think about it if you have ever cracked a lens it more than likely was not with the OEM screw in it. I know I have stripped out a few. As these are both small and can easily ship in a small padded envelope we decided to release a few Group Buys together so that you can have some stuff to do and save on shipping The short list Visor screw Reg $5 a set GB price $3.50 for all 4 (note the finish on the screw in the picture is wrong, it is being re plated now. The turn signal screws Red $1.75 each ($7.00 a set) GB price $3.75 a set And if you are planing to replace the screws you can get new lenses at a reduced price Amber set of 2 (reg $24) with screws $12 a set! Clear set of 2 (reg $32) with screws $16 a set! And yes while you are there I do have the new seals too. Yes reg $16.50 a set I can add in for $10 if added in with the screws. This will give you a quick and easy afternoon project and save some cash! So Who's interested? Attached thumbnail(s) Attached image(s) |
MM1 |
Apr 8 2020, 07:51 AM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I am - just got some NOS Hella clear turn lenses.
bbrock |
Apr 8 2020, 08:11 AM
Another great product! I believe those same screws are using on side markers too. Do you happen to also have the rubber washers that go under the screw head to seal the lens? I was getting ready to try to source some at the local hardware but they would be a nice addition to the screws. [edit: looking at the PET, it looks like the rubber washers are for the side markers only. Mine migrated to my turn signals somehow over the years.]
mb911 |
Apr 8 2020, 08:30 AM
914 Guru Group: Members Posts: 6,802 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Mark,
I actually need the screws.. I was just looking the other day for some.. Do you happen the turn signal decals for a 914-6? @mikey914 |
maf914 |
Apr 8 2020, 08:40 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I am in for screws, amber lenses, and seals.
mmichalik |
Apr 8 2020, 10:04 AM
MikeM Group: Members Posts: 689 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
I'll be in for two sets of each screw - (Visor and Lens)
Mikey914 |
Apr 8 2020, 10:10 AM
Another great product! I believe those same screws are using on side markers too. Do you happen to also have the rubber washers that go under the screw head to seal the lens? I was getting ready to try to source some at the local hardware but they would be a nice addition to the screws. [edit: looking at the PET, it looks like the rubber washers are for the side markers only. Mine migrated to my turn signals somehow over the years.] You know I recall there was a thin washer that was plastic on the front. Does that sound right? |
mb911 |
Apr 8 2020, 11:05 AM
Mikey914 |
Apr 8 2020, 11:13 AM
Got ya,
should be easy enough, but are they not currently available? Or just stupid expensive? |
mb911 |
Apr 8 2020, 11:21 AM
Mikey914 |
Apr 8 2020, 11:25 AM
At that price point I will do these. We also made a variant of the clam shell that we could market for 6 conversions too (IMG:style_emoticons/default/cool_shades.gif)
914bub |
Apr 8 2020, 11:57 AM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
I'm in for visor screws, lens screws, amber lenses and gaskets. Any chance they can ship with the updated speedo drive housing? I'm not in a hurry and can pay any time.
poorsche914 |
Apr 8 2020, 01:06 PM
T4 Supercharged Group: Members Posts: 3,087 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Interested in visor and lens screws as well as a set of amber lenses.
(IMG:style_emoticons/default/driving.gif) |
Mikey914 |
Apr 8 2020, 01:52 PM
I'm in for visor screws, lens screws, amber lenses and gaskets. Any chance they can ship with the updated speedo drive housing? I'm not in a hurry and can pay any time. Intended to be able to. They will be ready about the same time Also on another note we are reintroducing the surrounds with option to add LED headlights as an other stuck at home project. Any of these can be combined. The only issue we have is the front trunk metal, as it ships in it's own tube small stuff will add in, but it is it's own "box". |
second wind |
Apr 8 2020, 02:31 PM
Senior Member Group: Members Posts: 847 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
I'm in for some clear lenses and seals. The screws come with it, right? Do I need the visor screws? Is the new batch of visors in yet?
Thank you, gg |
Mikey914 |
Apr 8 2020, 02:39 PM
The screw are offered as stand alone so those that want the CW screws can get them. If you buy the hardware you can get the rest at a good discount. The focus was mainly on the hardware, but I guess you could say they were included as you will not get the discount without them.
(IMG:style_emoticons/default/beer3.gif) Update on the visors we are waiting for more material should be here next week. |
Craigers17 |
Apr 8 2020, 03:42 PM
Senior Member Group: Members Posts: 728 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
I am in for the turn signal screws, amber lenses, and seals.
Thanks, -Craig |
56kabrio |
Apr 8 2020, 08:01 PM
Member Group: Members Posts: 54 Joined: 1-December 05 From: Nashville, TN Member No.: 5,219 Region Association: None |
Mikey914 |
Apr 8 2020, 08:54 PM
Yes we are setting these up to be able to consolidate for those that want them. I did want to list all the GBs together but they get lost.
davehg |
Apr 9 2020, 12:40 AM
Member Group: Members Posts: 182 Joined: 19-September 17 From: PNW Member No.: 21,443 Region Association: Pacific Northwest |
Add me for one set of visor screws, and two sets of turn signal screws, and two sets of turn signal seals/gaskets.
The black car and the blue car thank you. |
Lo-Fi Version | Time is now: 23rd April 2024 - 05:44 AM |
