| tazz9924 |
Apr 4 2020, 11:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 749 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Heres the quick break down: My old car got totaled on the side of the road, i got a good settlement out of it and with the money im building A tube frame chassis 914 with Porsche Boxster suspension and a subaru turbo motor.
The goals: (Disclaimer some of these are really down the road and may not make the initial version 2.0, maybe 2.1 or so on and so forth. They are also goals so weather or not i achieve them, it’s something to shoot for.) Tube frame chassis, all made of DOM tube and when all when the car is fully built it should weigh 1600 ish lbs. The motor: It will have a subaru turbo motor. The initial version will see a 2.0 just so i can start having fun but eventually it’ll be a hybrid 2.5 making 400whp The suspension: It will all be porsche boxster same with the brakes so it should handle all the power and lack of weight im throwing at it. The body: It will be all fiberglass panels dzused on with the exception of the A pillar which will be a stock piece from a 914 but it will retain a vin tag. The only other stock 914 related thing will be pop up headlights which will be retained. Aero: This thing will have an extreme aero package. From the smooth underbelly with large rear diffuser and front splitter to canards and a chassis mounted rear wing, This “car” WILL have a presence like little else. Interior: Skip... JK this thing will have a digital dash, k tuned shifter, willwood pedal cluster, and a plaid racing seat. Thats about it, passenger seat is seen as optional at this point. So hopefully this should be good, i dont have much time, even in the covid 19 world we currently find ourselves in right now. It may not be a fast paced build but the goal is to have a roller by june... So lets get to building! OG car: The Crash: Whats Left: I dont have many parts left, I took all the good parts off sold what i could and kept what i needed. |
| tazz9924 |
Apr 5 2020, 08:52 AM
| gereed75 |
Apr 5 2020, 10:41 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,402 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
Interesting. Have been contemplating a similar midengine build using boxster suspension. Will be interested to see how this goes together!
| Mueller |
Apr 5 2020, 12:51 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Subscribed!
| cali914 |
Apr 5 2020, 12:58 PM
cali914 ![]() ![]() Group: Members Posts: 456 Joined: 26-April 06 From: Berkeley Ca. Member No.: 5,934 Region Association: Northern California |
i like (IMG:style_emoticons/default/biggrin.gif)
| tazz9924 |
Apr 5 2020, 07:26 PM
| Andyrew |
Apr 5 2020, 09:02 PM
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,380 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California
This will be a great build!!!! Are you going to document it on the YT channel?
| Tbrown4x4 |
Apr 6 2020, 02:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 708 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None
Loved your old car. It'll be great watching this!
| tazz9924 |
Apr 6 2020, 05:45 AM
| gereed75 |
Apr 6 2020, 06:28 AM
What do you call your tube channel?
| jmitro |
Apr 6 2020, 06:42 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None
very cool!
| tygaboy |
Apr 6 2020, 08:44 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,688 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
| tazz9924 |
Apr 6 2020, 12:28 PM
What do you call your tube channel? Ziptied, a place where u can see me do dumb things with cars. https://m.youtube.com/channel/UCwkC6muunVD72SHwE9ZoXeA |
| tazz9924 |
Apr 6 2020, 09:03 PM
Spent the day adding in the wings of the chassis under where the driver and passenger(?) sits and honing in my tube bender. Turns out my bending die is advertised as a 7” radius but in reality its an 8.125” radius (which made me waste some good metal to find out). More on what i was bending tomorrow when im done.
| Mueller |
Apr 7 2020, 08:46 AM
Looks great so far.
Have you measured the floor jacks to ensure same height or not grossly off? |
| Andyrew |
Apr 7 2020, 05:37 PM
This will be a great build!!!! Are you going to document it on the YT channel? I certainly will! (IMG:style_emoticons/default/beerchug.gif) I miss those things |
| tazz9924 |
Apr 7 2020, 05:59 PM
Looks great so far. Have you measured the floor jacks to ensure same height or not grossly off? Yep i welded them in place to ensure the same height and to dissuade me from using them on something else. Also made them level because without much weight on them they dont sit flat. |
| rgalla9146 |
Apr 7 2020, 06:27 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,850 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Looks great so far. Have you measured the floor jacks to ensure same height or not grossly off? Yep i welded them in place to ensure the same height and to dissuade me from using them on something else. Also made them level because without much weight on them they dont sit flat. the floor is flat too ? garage floors are not exactly a surface plate. looks are deceiving. |
| Andyrew |
Apr 7 2020, 07:47 PM
Flat and straight enough is flat and straight enough for a home build (IMG:style_emoticons/default/smile.gif) I'm sure he can build enough adjustability into the mounts to correct any twist in the chassis.
| tazz9924 |
Apr 7 2020, 08:48 PM
Flat and straight enough is flat and straight enough for a home build (IMG:style_emoticons/default/smile.gif) I'm sure he can build enough adjustability into the mounts to correct any twist in the chassis. Correct however i regularly check measurements and after a good amount of welding .35 degrees is all the twist so far. My garage floor is absolutely not flat but once all the welding is done im gonna shim the stands to level it out. Too bad a chassis table is so damn big and expensive.... next time i guess. |
Lo-Fi Version | Time is now: 7th November 2025 - 05:43 PM |
