1974 1.8L D jet, what is the best exhaust for alittle more power? |
zfisher6164 |
Jan 4 2020, 01:58 PM
Newbie Group: Members Posts: 41 Joined: 19-January 19 From: California Member No.: 22,809 Region Association: None |
What is the best bolt on exhaust for a stock 1.8L Djet? I am looking at many different models of Bursch but not sure which one.
thanks |
Coondog |
Jan 4 2020, 02:08 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
Chris H. |
Jan 4 2020, 03:08 PM
Senior Member Group: Members Posts: 4,027 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
A stock 1.8 is going to be L-Jet, just FYI.
zfisher6164 |
Jan 4 2020, 04:40 PM
Spoke |
Jan 4 2020, 04:56 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
zfisher6164 |
Jan 4 2020, 04:59 PM
1.8L ...for a little more power? Drop the 1.8L and put in a 2L or 2056. I had a 1.7L stock muffler then free flow exhaust; no difference. Dropped the 1.7L and put in a 2056; wow. It's like a different car. That is the answer I was expecting, did you buy a 2056 or have one built by scat or raby or other? |
Rand |
Jan 4 2020, 05:26 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Bolting on exhaust will not give you magic power. The exhaust is part of a system that needs to be tuned to work together. You can bolt on the highest dollar exhaust bling and not see improvement. It's a system.
thelogo |
Jan 4 2020, 05:48 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
What is the best bolt on exhaust for a stock 1.8L Djet? I am looking at many different models of Bursch but not sure which one. thanks That 1.8 will not make your heart race But it will get ya there . It cost big money for a more power Alot more then just the exausht |
dr914@autoatlanta.com |
Jan 4 2020, 06:03 PM
914 Guru Group: Members Posts: 7,811 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Spoke |
Jan 5 2020, 09:28 AM
1.8L ...for a little more power? Drop the 1.8L and put in a 2L or 2056. I had a 1.7L stock muffler then free flow exhaust; no difference. Dropped the 1.7L and put in a 2056; wow. It's like a different car. That is the answer I was expecting, did you buy a 2056 or have one built by scat or raby or other? I picked up the 2056 from Garold Shaffer for less than $1k including dual weber carbs. Put SSHE on the exhaust with Bursch muffler. I removed the heads and inspected everything and put it back together. It runs good and pulls real hard. Huge difference over the 1.7L/1.8L engines I had in the car. |
rbzymek |
Jan 18 2020, 10:29 PM
Member Group: Members Posts: 195 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest |
I replaced my horribly noisy Bursch with a Triad exhaust on the 1.8L. Then I purchased a Scat 2056 long block and did the engine switch. Excellent drivability with the L-Jet FI and sounds GREAT. Also replaced the fuel lines, master cylinder and media blasted the fan housing on the same go.
ClayPerrine |
Jan 19 2020, 12:08 AM
Life's been good to me so far..... Group: Admin Posts: 15,395 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I replaced my horribly noisy Bursch with a Triad exhaust on the 1.8L. Then I purchased a Scat 2056 long block and did the engine switch. Excellent drivability with the L-Jet FI and sounds GREAT. Also replaced the fuel lines, master cylinder and media blasted the fan housing on the same go. Did you put a bus throttle body on it? That will really wake it up. L-Jet bus throttle body conversion. |
rbzymek |
Jan 20 2020, 07:14 PM
Clay,
Thank you for the recommendation. I will certainly do the upgrade to complement the 2056 and the 42x38 valves. It's already pretty zippy as it is but more is better. Ray |
Lo-Fi Version | Time is now: 20th April 2024 - 10:26 AM |
