FS-Awesome 74 914 GT with 993 3.6 & Alloy 915, FS. Viper Green, Steel Flared Built GT with 1995 993 3.6 |
BRC911 |
Dec 9 2019, 10:57 AM
I'm new here ... Group: Members Posts: 0 Joined: 23-September 19 From: Madison, WI Member No.: 23,491 Region Association: Upper MidWest |
I have a Hot Rod Build 1974 Porsche 914 GT. It was a 914/4 originally & in Silver. This 914 is now a Viper Green GT build and has many upgrades.
This build started in 2011 with a rust free California car, steel factory flares were welded on. Back dated bumpers & GT valances to match. Porsche oil cooler mounted up front with modified front bumper opening. European style front turn signal lenses. Side marker deleted. Late model space saver spare mounted up in the front trunk. It still has a california title. This car was shipped to the UK in 2012. In the UK, a windows out repaint in Viper Green was performed in 2012. Car has done maybe a 1,000 miles since it's initial build. The engine is from a 1995 993 3.6 ltr. With the engine upgrades, it should be around 300HP. The engine has about 29,000 miles on it. It has Billy Boat stainless headers w/heater boxes. Magnaflow mufflers, K & N air filter and still retaining the stock Porsche Bosch fuel injection. Lightweight Hi-torgue starter. It also has the Late style 3.6 ECU. The gear box is a 1985 Alloy Case 915. Rebuilt when installed in 2011. It has a Guard LSD. Cable Shifter shifter and a cable clutch set up as well. Sachs sports-clutch. 915 axles with big CV joints. The suspension has Bilstein RSR front struts, Tarret hollow adjustable front sway bar. Stock 914 rear sway bar. 911 front torsion bars. Aluminum front axle beam from a 911 SC. The rear trailing arms have been reinforced along with the rear frame stiffening kit sections welded in. 5 lug conversion. Front A-arms & rear trailing arms have Elephant Racing rubber bushing installed. Rear Koni externally adjustable rear shocks with Bicknell Coilovers & Eibach springs. Weltmeister adjustable front camber plates with Monoballs. New 930 u-joints in the steering shafts & new lower front ball joints. The front brakes are Porsche 930 Turbo/Brembo units with stainless hoses. Front & rear rotors are vented & cross drilled. 914/6 rear calipers and a working E-brake. The wheels polished & painted real Porsche 930 Turbo Fuchs. 16 X 7 & 16 X 9 The interior has leather seats. New 914Rubber dash pad. The windshield was also just resealed. The door panels are Marine cloth with GT interior door handles. Momo Competition steering wheel. The pedals were rebuild & bushed. New 3 point retractable seat belts. New carpet. New Coco Mats. All weatherstripping was replaced in 2012. Not included but, I have a new set of Minilites that we could work into the deal as well. While this 914 GT was in the UK, it was in the magazine Ultimate Porsche, Nov 2017. Nice article and it was on the cover. This 914 GT is located in Madison, Wisconsin. We are asking $72,000 Wire transfer or cash. Might consider a partial trade. [attachmentid=721 999][attachmentid =722004] Attached image(s) |
914z |
Dec 9 2019, 02:08 PM
Newbie Group: Members Posts: 35 Joined: 11-September 04 From: Los Angeles, CA Member No.: 2,737 |
I have a Hot Rod Build 1974 Porsche 914 GT. It was a 914/4 originally & in Silver. This 914 is now a Viper Green GT build and has many upgrades. This build started in 2011 with a rust free California car, steel factory flares were welded on. Back dated bumpers & GT valances to match. Porsche oil cooler mounted up front with modified front bumper opening. European style front turn signal lenses. Side marker deleted. Late model space saver spare mounted up in the front trunk. It still has a california title. This car was shipped to the UK in 2012. In the UK, a windows out repaint in Viper Green was performed in 2012. Car has done maybe a 1,000 miles since it's initial build. The engine is from a 1995 993 3.6 ltr. With the engine upgrades, it should be around 300HP. The engine has about 29,000 miles on it. It has Billy Boat stainless headers w/heater boxes. Magnaflow mufflers, K & N air filter and still retaining the stock Porsche Bosch fuel injection. Lightweight Hi-torgue starter. It also has the Late style 3.6 ECU. The gear box is a 1985 Alloy Case 915. Rebuilt when installed in 2011. It has a Guard LSD. Cable Shifter shifter and a cable clutch set up as well. Sachs sports-clutch. 915 axles with big CV joints. The suspension has Bilstein RSR front struts, Tarret hollow adjustable front sway bar. Stock 914 rear sway bar. 911 front torsion bars. Aluminum front axle beam from a 911 SC. The rear trailing arms have been reinforced along with the rear frame stiffening kit sections welded in. 5 lug conversion. Front A-arms & rear trailing arms have Elephant Racing rubber bushing installed. Rear Koni externally adjustable rear shocks with Bicknell Coilovers & Eibach springs. Weltmeister adjustable front camber plates with Monoballs. New 930 u-joints in the steering shafts & new lower front ball joints. The front brakes are Porsche 930 Turbo/Brembo units with stainless hoses. Front & rear rotors are vented & cross drilled. 914/6 rear calipers and a working E-brake. The wheels polished & painted real Porsche 930 Turbo Fuchs. 16 X 7 & 16 X 9 The interior has leather seats. New 914Rubber dash pad. The windshield was also just resealed. The door panels are Marine cloth with GT interior door handles. Momo Competition steering wheel. The pedals were rebuild & bushed. New 3 point retractable seat belts. New carpet. New Coco Mats. All weatherstripping was replaced in 2012. Not included but, I have a new set of Minilites that we could work into the deal as well. While this 914 GT was in the UK, it was in the magazine Ultimate Porsche, Nov 2017. Nice article and it was on the cover. This 914 GT is located in Madison, Wisconsin. We are asking $72,000 Wire transfer or cash. Might consider a partial trade. [attachmentid=721 999][attachmentid =722004] REALLY PURTY!!!! THAT IS A GREAT PRICE! GLWTS!!!! (IMG:style_emoticons/default/beerchug.gif) |
sixaddict |
Dec 9 2019, 03:21 PM
Senior Member Group: Members Posts: 799 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Lets see this one or the real tangerine six for about the same $$ ...Beautiful car though !
Cairo94507 |
Dec 10 2019, 08:33 AM
Michael Group: Members Posts: 9,714 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Man, that is a whole lot of car for not a lot of money fellas. I love the color too. GLWTS (IMG:style_emoticons/default/beerchug.gif)
eric9144 |
Dec 10 2019, 09:57 AM
Advanced Member Group: Members Posts: 2,733 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
matthepcat |
Dec 10 2019, 11:04 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Nice car. For the asking price, I suggest adding a photo collection link with videos and pictures of receipts of work to the car. Is the engine documented? Like does it have a receipt for the rebuild with upgrades? (If not, then there is no proof).
BRC911 |
Dec 10 2019, 07:39 PM
Hi.
Thanks for compliments. This 914 still has it the UK plates on it. Being in Wisconsin I am not sure what is needed to update it or even what non-op is in California. I have the California title and I have plates that were good till 2012. You can PM me to let me know what I would need to do to make it easy for a possible California buyer. Most of the work was done in by a gentleman in Oakland. We did not get any receipts with the car back in 2012. The engine was not rebuilt but was supposed to only have 28,000 miles on it. To the interested buyers, If need be I can give the owner from Oakland who did most of the work in 2010-2011 and I have a Dropbox with 200+ pics I can send to you. Thanks, Jim |
mb911 |
Dec 11 2019, 08:22 PM
914 Guru Group: Members Posts: 6,812 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Wow so close to me. Never knew it was in Madison.. Didn't we see this build on here?
BRC911 |
Jan 18 2020, 08:52 PM
Hi.
Bump. Open to offers. Thanks, |
Lo-Fi Version | Time is now: 26th April 2024 - 04:23 PM |
