yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,455 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
I've been sitting on what I believe to be a good, used transmission. I got it from a friend who knows these cars VERY well, but that was a long time ago and I always like to verify these things (within reason) myself. I'm changing out my clutch and my box needs some work, so now is the time to do it. It's not the end of the world if I have to swap my old box back in...
I got new seals all around for it, but is there anything I can check other than shifting through the gears on the bench to validate the syncros aren't toast? I'd rather not pull the stack... Thanks. -Aaron |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,007 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I think you'd have to pull the stack to assess condition more accurately
if it shifts through all of the gears... then you know at least that its not broken or mis assembled.... but I don't think you can assess the wear to the slider and its ability to not grind without pulling the stack.... or driving it in a car. |
yeahmag |
That's what I thought. Just making sure I didn't overlook something.
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
You could also pull the gear stack and ship it to Dr. Evil to have him evaluate it. I understand it can be shipped in a cooler much cheaper than shipping an entire transmission.
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
Follow up on Aarons question. I have rebuilt a spare...actually John Larson did the rebuild before he passed.
I want to bench test the slider engagement. Is there any position diagram that shows the shift lever position ...meaning at the trans and the gear No.? Thought this might be on Dr. Evils CD? |
yeahmag |
gtbarnes |
Newbie ![]() Group: Members Posts: 35 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States ![]() |
First gear synchro is worn on the replacement box and it’s obviously been apart as both gaskets on either side of the intermediate plate are torn. I guess this will be the box that I do my rebuild on… ![]() Wow...brand new 1st dog teeth and new 1st synchro band in there and your down about thyat? pull it on out and see if they did any more(prob not tho) |
Montreal914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,854 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California ![]() ![]() |
First gear synchro is worn on the replacement box and it’s obviously been apart as both gaskets on either side of the intermediate plate are torn. Question is; do you trust the thickness of that gasket between the intermediate plate and case? That is your pinion depth adjustment... (IMG:style_emoticons/default/sad.gif) |
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,302 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
Follow up on Aarons question. I have rebuilt a spare...actually John Larson did the rebuild before he passed. I want to bench test the slider engagement. Is there any position diagram that shows the shift lever position ...meaning at the trans and the gear No.? Thought this might be on Dr. Evils CD? ![]() |
NARP74 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,375 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains ![]() |
Thanks for sharing that. I started making my own, pencil and scrap paper for when I need it. Lost the paper...
gtbarnes |
First gear synchro is worn on the replacement box and it’s obviously been apart as both gaskets on either side of the intermediate plate are torn. Question is; do you trust the thickness of that gasket between the intermediate plate and case? That is your pinion depth adjustment... (IMG:style_emoticons/default/sad.gif) If the gasket is black or grey I would say "no". If its tan and there is at least 2 of them, then, "maybe". I think a 1st gear job was done there and does have some miles on it but looks better than most. Since the gasket got separated I would go ahead and pull out the guts and see if the shafts have been unbolted before. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,953 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Bench shifting a trans means absolutely nothing. Just like saying an engine turns over. Either one could have every single part worn out and still turn or drop into gear. We even had a 3.6 engine with a broken crank that still turned over.
Opening the box up and a visual inspection is the only way to tell. A quick way for me to tell if a box is even a good core is to remove the side cover and check the R&P. A poor set with corrosion or damage means it’s no good for a rebuild. |
Lo-Fi Version | Time is now: 1st July 2025 - 10:06 PM |
