> Directional switch return to off, New switch - still not returning
North Coast Jim
post Dec 2 2017, 01:38 PM
Changed out both the Directional switch and the Wiper switch in the 914 a week or so ago. Seems to be working fine EXCEPT - the wiper return to off capability still doesn't work.
I have the following steering wheel, part number 914-347-8041, a hard plastic phenolic ?? wheel with the following return post, see pics. Seems the return post isn't long enough to mate with the switch mechanism. Is it broken off or is there another part I should be looking for ??
I've scoured the World for previous posts on this subject to no avail. Or maybe I'm still a rooking at looking
Thanks all
Attached ImageAttached Image
JamesM
post Dec 3 2017, 12:31 AM
Buy about 20 turn signal switches from as many different manufactures as possible and you might find one that doesn't completely suck out of the whole batch if you are lucky. Granted it will still suck it just might not suck so bad that it actually does what it is supposed to. At least that has been my experience with all the garbage repo turn signal switches being sold today.
You may be able to increase your chances of success by replacing the canceling ring on the wheel itself as they tend to have a grove worn in them after 45 years but bottom line the switches themselves are just being manufactured with horrible tolerances.
Surprisingly of all the sources i have tried so far the Meyle branded ones have been the worst. Good luck! If you find a good supply let me know as i am still looking.
post Dec 3 2017, 08:25 AM
PM Mark Heard "914SIXER". He scours the internet and comes up with OEM replacement parts all the time and he doesn't Scalp you, either! (IMG:style_emoticons/default/av-943.gif) I bought 2 turn signal assemblies from him. One to use and one as insurance as their numbers are dwindling.
mzalanka
post Dec 3 2017, 12:32 PM
I have dealt with this same issue. It shouldn’t be too hard to troubleshoot. My experience was that it was an alignment issue.
First off - can you cause the switch to reliably cancel by manually pushing the white tab on the switch up or down with the wheel off?
North Coast Jim
post Dec 3 2017, 01:12 PM
QUOTE(mzalanka @ Dec 3 2017, 01:32 PM) *
The tab push does cancel the directionals. I'm thinking it's a depth or location issue with the cancel tab located on the backside of the steering wheel hub.
Were there different lengths for this tab ?? Viewed a Buddies wheel and his had a metal tab vs the plastic one shown here. It was also longer.
SirAndy
post Dec 3 2017, 01:23 PM
Resident German
QUOTE(North Coast Jim @ Dec 2 2017, 11:38 AM) *
Just to clarify, you are actually talking about the blinker cancel, not a wiper cancel?
mzalanka
post Dec 3 2017, 01:27 PM
Ok good. You’ve ruled out a problem with the switch.
IMO it’s not a length but an alignment issue. I have two rings with plastic tabs of different length (one cut down 1/8” by a P.O.) and that makes no difference. You can try to realign a mm or two by loosening the four switch screws and shifting the whole switch assembly left while tightening, then doing the same with the cancel ring on the hub (toward the black semi-ring) and tightening. Also make sure the black semi-circle tab is at 3’oclock when installed.
This still might not fix it but it’s been known to work.
North Coast Jim
post Dec 3 2017, 03:02 PM
QUOTE(SirAndy @ Dec 3 2017, 02:23 PM) *
Correct Blinkers
North Coast Jim
post Dec 3 2017, 04:08 PM
Blinkers sorry
HansJan
post Dec 3 2017, 04:22 PM
Valy
post Dec 3 2017, 10:54 PM
Is the canceling tab on the steering wheel mounted in the correct position?
There are about 3 positions you can mount it in but only one works. The steering wheel hub can also be mounted incorrectly (the plastic hub that connects to the steering wheel and holds the canceling ring)
Sorry, but I don't have a correct picture handy.
Jonathan Livesay
post Dec 4 2017, 10:43 AM
QUOTE(Valy @ Dec 3 2017, 08:54 PM) *
Yes, the tab on the steering wheel has to be mounted so that it is on the same side as the white plastic cancelling mechanism when the steering wheel is mounted. In other words if you are looking at your steering wheel as pictured in your second picture, when you go to install it on the shaft flip it over from top to bottom not from side to side. Also don't over tighten the 4 screws that hold the lever in place that can cause the cancelling mechanism to bind up.
North Coast Jim
post Dec 6 2017, 10:30 AM
Thanks all for the valuable input. Will try these out when I get the gauges back from rebuild. Should be another 30 days or so.
post Apr 25 2025, 07:08 PM
PM sent Need to find out how you finally fixed it
post Jul 11 2025, 04:44 PM
Is the Dansk TS switch known to not cancel ?
barefoot
post Jul 11 2025, 05:23 PM
QUOTE(Jonathan Livesay @ Dec 4 2017, 12:43 PM) *
Don't quite understand your steering wheel tab position. If it's at the 3 o'clock position, it'll sit directly on top of the self cancelling tab on the turn signal switch.
My steering wheel tab sits at about the 10 o'clock position so must turn the steering wheel much further in one direction than the other to self cancel, but they do work.
Barefoot
mm911
post Jul 12 2025, 11:28 AM
I had the same problem . The turn signal would not cancel. The four mounting screws were too tight. I set them at firm but not too tight. Works now. Thanks to Dr. 914
914sgofast2
post Jul 12 2025, 02:57 PM
I had the same problem when replacing the turn signal switch on my 1970 car with an aftermarket switch assembly from Dansk. Finally I had to shim the operating arm screwed to the bottom of the steering wheel hub with 3 flat washers (1 washer under each of the attaching screws) to make the tab portion stick down far enough into the turn signal switch in order to move the little arm up or down when the turn signal arm was moved, and thereby turn off the blinkers. I also agree that that the 4 mounting screws which hold the turn signal switch must not be screwed on too tightly, and don't forget to use the small metal tubular spacers on those 4 screws where they pass through the turn signal switch.
post Jul 12 2025, 03:34 PM
Thanks, good tips (IMG:style_emoticons/default/smile.gif) Were there supposed to be 4 small washers under the switch ? The first time I pulled the switch 4 very small washers were under the switch ???
914sgofast2
post Jul 13 2025, 02:17 PM
No washers under the switch. I was referring to the tiny metal tube spacers inside the switch under the 4 holes the tiny screws go through to secure the switch to the steering column. The only washers I was describing were additional washers added underneath the operating tang mounted on the bottom of the steering wheel hub in order to move the tang lower into the switch assembly so it can trigger the switch to turn off once a turn has been completed.
- Lo-Fi Version Time is now: 30th July 2025 - 06:23 PM
