| sdoolin |
Aug 17 2015, 06:52 AM
Member ![]() ![]() Group: Members Posts: 417 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Windshield mounted rearview mirror came off in my hand the other morning. It was mounted in the wrong place anyway and would not allow for full movement of the sun visors. So, time to re-affix.
I have the sticky pad on order from Pelican, but am having trouble removing the mirror from the mounting base? I have removed the screw, but still the thing does not want to budge. Is there a trick to this? |
| MSHax |
Aug 17 2015, 07:40 AM
Member ![]() ![]() Group: Members Posts: 55 Joined: 8-August 15 From: California Bay Area Member No.: 19,039 Region Association: Central California |
Windshield mounted rearview mirror came off in my hand the other morning. It was mounted in the wrong place anyway and would not allow for full movement of the sun visors. So, time to re-affix. I have the sticky pad on order from Pelican, but am having trouble removing the mirror from the mounting base? I have removed the screw, but still the thing does not want to budge. Is there a trick to this? That can get tricky. Not to scare you, but to make you aware of what can happen, I watched a glass vetran at a glass shop crack my windshield on my 69 nova as he attempted to "pop" the mirror off. As far as the visor issue, I found this thread. http://www.914world.com/bbs2/lofiversion/i...hp?t221574.html I'm doing the bmw mirror. You can find them in eBay for cheap if you search "Porsche 914 mirror bmw" |
| screenguy914 |
Aug 17 2015, 08:27 AM
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
Windshield mounted rearview mirror came off in my hand the other morning. It was mounted in the wrong place anyway and would not allow for full movement of the sun visors. So, time to re-affix. I have the sticky pad on order from Pelican, but am having trouble removing the mirror from the mounting base? I have removed the screw, but still the thing does not want to budge. Is there a trick to this? Unless the PO chemically attached the two together for some reason, the mirror and mount should separate with shock. While supporting an edge of the mount on a vise anvil, bench top or equivalent, use a brass drift and hammer and tap the mirror off the mount. Enlist a helper to provide an extra pair of hands. Unfamiliar with the "sticky pad" from Pelican, but the off-the-shelf products available from my FLAPS were a total failure. Mirror fell off within a few miles. I finally used a dab of 2-part epoxy (e.g. JB Weld) for a more or less permanent mounting solution. YMMV. Measure twice and mount once. Sherwood |
| Dave_Darling |
Aug 17 2015, 09:01 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,318 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I was able to use a tube of stuff from my FLAPS to hold the rear view mirror on my 914's brand-new windshield. It has held for ~5 years so far. Not sure if the windshield being new played into it at all, though.
If you've removed the screw that holds the mirror arm onto the mirror base, I'd try wiggling the joint. Someone may have glued it, or it may be corrosion or dirt or some such that is holding the joint together. --DD |
| sdoolin |
Aug 17 2015, 09:15 AM
QUOTE the mirror and mount should separate with shock. While supporting an edge of the mount on a vise anvil, bench top or equivalent, use a brass drift and hammer and tap the mirror off the mount. I especially like the first bit "should separate with shock" I can't see this going wrong at all. I'm going to use a hammer and drift in close proximity to the mirror - which is glass. |
| Cuda911 |
Aug 17 2015, 09:20 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
I get the impression from original post that the base is off of the glass, but he's having a problem separating the mirror "stem" from the base.
Another vote for just prying the mirror off of the base. They can stick together. About four months ago, I found a small bolt on the floor of my car. Had no idea what it was from, so put it aside. Last week as I was adjusting the mirror, it fell off in my hand. Turns out that it was the mirror bolt that I had found, and the mirror stayed attached to the base just fine for months and miles and many adjustments before falling off. I still have no idea how the mirror managed to stay attached to the base during all that. |
| Tom_T |
Aug 17 2015, 11:34 AM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
I've never had to separate the two parts to remount a mirror with the sticky mounting pad, & as a unit it's easier to position correctly to not interfere with the visors & for rear vision. No need to separate the two.
The keys are to use the actual Porsche, 3M or known quality OEM sticky pad (cheapos are & always have been out there), & to completely clean the windshield & base with a razor blade & alcohol or adhesive remover, then adhere the one side of the double-stick pad to the base first & smooth & push it down on the base (with the wax paper backer still on the windshield side), then position a few mm's above the glass without touching it, then push onto the glass & slightly wiggle it slightly with medium pressure to get good adherence (not too hard it can break/crack glass). The big keys with any adhesives are the absolute cleanliness of both surfaces & "only one touch" stick to each surface. I'd done it a few times in the decade & +/-150k miles that my 914 was my DD! Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
| GeorgeRud |
Aug 17 2015, 04:45 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Years ago, I was told that using two of the adhesive pads would hold it better (to make up for the slight curve in the glass?), and mine's held that way for years.
| kid914 |
Aug 17 2015, 07:19 PM
ALWAYS lead...NEVER follow!!!! ![]() ![]() ![]() ![]() Group: Members Posts: 2,539 Joined: 9-March 11 From: Canada Member No.: 12,811 Region Association: Canada |
I went the BMW modified version...and never looked back.( pun intended) lol
Attached thumbnail(s) |
| vw505 |
Aug 17 2015, 07:50 PM
Member ![]() ![]() Group: Members Posts: 228 Joined: 17-April 03 From: San Antonio, TX , Navy retired Member No.: 579 Region Association: None |
Anyone know what year bmw?
| zambezi |
Aug 18 2015, 07:45 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
http://www.ebay.com/itm/Porsche-914-interi...618&vxp=mtr
There is always one listed on ebay as long as I have looked. |
| Kansas 914 |
Aug 18 2015, 09:00 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,006 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
http://www.ebay.com/itm/Porsche-914-interi...618&vxp=mtr There is always one listed on ebay as long as I have looked. (IMG:style_emoticons/default/agree.gif) I have purchased at least 2 from Mack914-6. Always delivers a great product. |
| JawjaPorsche |
Aug 18 2015, 09:15 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
http://www.ebay.com/itm/Porsche-914-interi...618&vxp=mtr There is always one listed on ebay as long as I have looked. (IMG:style_emoticons/default/agree.gif) I have purchased at least 2 from Mack914-6. Always delivers a great product. (IMG:style_emoticons/default/agree.gif) I love my BMW mirror. |
| sdoolin |
Aug 19 2015, 08:48 AM
Thanks for all the info. I have managed to separate the mirror from the base, and (as mentioned) have the OE style sticky pad on order from Pelican. However, I have a new problem.
It seems that whilst my little brother was "cleaning" my bench so that he could re-stain an old set of Bose 901 speakers he "cleaned" the little screw that attaches mirror to base right out of my existence. Anyone know the size/dimension of that screw or have a spare? I'd like to stay OE on this as opposed to the BMW mirror (realizing I may have no choice now). |
| Dave_Darling |
Aug 19 2015, 09:50 PM
Mr. PET says: "pan-head screw AM 2,6 X 15"
That's not familiar notation to me, though. I remember it being a somewhat long screw with a lot of bare shank. --DD |
| Cuda911 |
Aug 19 2015, 10:12 PM
I don't have the dimensions, but it's about an inch or so long.... no bare shank (by that you mean unthreaded?).
| Cairo94507 |
Aug 19 2015, 10:22 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,564 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I have one of the BMW conversions for my Six. I have never liked the mirror affixed to the windshield because it makes it harder to clean the windshield and looks better with the BMW part. Yeah, I know.....another mod to my Six (IMG:style_emoticons/default/stirthepot.gif)
| sdoolin |
Aug 20 2015, 06:21 AM
QUOTE Mr. PET says: "pan-head screw AM 2,6 X 15" Thanks so much. Mine was threaded all the way. |
| Cfletch |
Jan 30 2026, 06:13 PM
Member ![]() ![]() Group: Members Posts: 228 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
Going to revive this thread as I am looking for this BMW mirror. My current mirror keeps falling off the new adhesive pad as if its too heavy or something weird- its an aftermarket mirror so makes sense I guess.
Every BMW E30 mirror I see does not have any holes in it like the pictured one in this thread and I cant seem to find anyone in various threads actually specify the part number of the mirror, have seen E30 mirrors mentioned and E28 mirrors mentioned but want to confirm. Thanks |
| Spoke |
Jan 30 2026, 07:56 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,333 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
The mirror fell off last year so i bought one of the glue kits from my FLAPS. If you go this route and the instructions say just use 1 drop of glue, use 1 drop of glue. My initial instincts of use as much glue as possible was a total failure.
As a model builder since youth, when at first you don't succeed, go back and read the instructions. |
Lo-Fi Version | Time is now: 4th February 2026 - 08:11 AM |
