62 Pages V  1 2 3 > »
> CptTripps' Restoration 2 - The Grey Matter Build, Back in Doug’s garage
CptTripps
post Aug 19 2013, 03:00 PM
:: Punch and Pie ::
Hey gang!
I'm back in the mix, and getting ready for another 914 restoration. Not sure this will play out as well as it did Last Time, but we'll give her a go and see what I can come up with!
After I find the right starting-point, here's what I've been dreaming of doing to it.
Subaru EJ20 Turbo 4 engine & Trans. (250-275hp target)
Steel flares
5-bolt hubs
Boxster brakes
Stiffen up the body. (MAYBE a roll-bar.)
Satin silver paint, blacked-out chrome, black satin rims...with colorful calipers.
I think I've found the right starting-point car (70-1.7 with carbs) so I'll drive it a bit while I'm stock-piling parts. That way I can start the project in earnest this winter while the snow falls.
I'm going to use the 901 side-shift trans I have in my basement to mount up to the EJ20 after I can locate a decent one. That way, I should be able to get everything right and then mount it up a lot easier after I drop the 1.7 out. (Best intentions...always lead to disappointment, but I'll try anyway.)
Things I learned the last time:
* Do the body work all the way up to the primer, then let a pro take it from there.
* It's much easier to work when you have a lot of light.
* Garage heaters are your friend.
* When in doubt...STOP and look for an answer. (Doubling your bad efforts never works.)
* Wearing those blue latex gloves alleviates embarrassing situations in meetings
* The search button is your friend. (Spelling is also...thanks Andy.)
Here we go!
UPDATE: I ended up with a 1975 with a V8 conversion as a starting point.
UPDATE 2: The engine I found had a good Trans on it, so I'm going to have a Subaru 5MT not a 901.
UPDATE 3: 350 is my new HP goal
UPDATE 4: I'm naming the project "Grey Matter" because the car is going to be a lot more than just a restoration. That...and project names are cool. (IMG:style_emoticons/default/biggrin.gif)
UPDATE 5: April 17th is the "due date" to have it complete. Not as fast as my last build, but there is a LOT more to this one.
CptTripps
post Aug 19 2013, 03:07 PM
:: Punch and Pie ::
Here's what I'm shooting for as a color combo...but on a Carrera GT.
jimkelly
post Aug 19 2013, 03:25 PM
Delaware USA
talk to dbcooper - seems he would have gone suby 6 if he were to do it over - unless I recall a post incorrectly.
though how cool is it to be running a closed deck suby with boost : )
CptTripps
post Aug 19 2013, 05:33 PM
:: Punch and Pie ::
I'm digging through a LOT of threads this week. Looks like I need to decide pretty quickly if I want the 901 transmission, or if keeping it will be more work than it's worth. The idea of buying a complete engine/trans combo that could bolt on a lot easier is appealing. The cable-shift transmission conversion is what has me puzzled right now. I need to plot/plan and talk to a few people first.
I guess Ian is on/returning from his honeymoon, so I'll hold off a few weeks before I make that decision.
Just ordered my steel flares and the rear floorboard. I KNOW I'll need that for either of the cars I'm looking at right now, so it was a safe bet to get them in sooner rather than later. Wish I could remember who I got the door panels from last time. I need to dig into that old email account and see if I can find it. Going to get the chassis stiffening kit too. Sad about Engman...he was a 1-stop-shop for a lot of the things I need this time around.
Chris H.
post Aug 19 2013, 05:50 PM
For that much power you should do a 5MT Subie trans...much better fit for your application. Bolts right up with no problem, no adapter required. We're all muddling through the cable shifter thing but many people have done it successfully. I'll be attempting it in a few weeks myself.
CptTripps
post Aug 19 2013, 06:08 PM
:: Punch and Pie ::
So what engine/trans combo should I be hunting for? I was looking at EJ20G, EJ20H, and EJ208 engines on eBay. There seem to be a lot of variances in what people here are using.
I'm also confused as to if I should be buying with/without the ECU.
CptTripps
post Aug 19 2013, 06:13 PM
:: Punch and Pie ::
Nevermind...figured out that the 5MT is about the ONLY trans that came with the EJ20.
Chris H.
post Aug 19 2013, 06:21 PM
Any 5MT will bolt up but you should look for one that was mated to a "turbo" car. The newer the better is the rule. Mine is from a stock 2006 WRX that had a 2.5T in it. I bolted it to a 3.3L SVX engine. Haven't driven it yet but it LOOKS REALLY GOOD!
Someone else will chime in on the engine piece I'm sure. EDIT: Get the ECU and engine wiring harness for sure.
Here's a thread you might want to check out. ON A PRIVATE ROAD some guy was embarassing kids in their Mustangs and GTOs with his lowly 914 2.0T. I'm sure it wasn't DBCooper though...he was just taping it. Note how quickly the 914 pulls away...
Link
CptTripps
post Aug 19 2013, 09:49 PM
:: Punch and Pie ::
QUOTE(Chris H. @ Aug 19 2013, 08:21 PM) *
The idea of a bigger power plant is fun and all, but I've always been a fan of a 4-cyl turbo. I'm not going to be tracking the car at all, so the gain in HP for tooling around with one of my boys is what I'm aiming for. 3.3 would be a bit of overkill for...me anyway.
Just purchased the Boxster calipers and the adapters from Rich. Ordered the rear 1/2 of the floor pan, and Flares from AA. Looks like I'll be picking the car up Wed night to drive home. Should be fun!
TravisNeff
post Aug 20 2013, 11:44 AM
Good to see you back!
CptTripps
post Aug 20 2013, 12:49 PM
:: Punch and Pie ::
QUOTE(Travis Neff @ Aug 20 2013, 01:44 PM) *
Thanks Travis!
Picking up my car tomorrow...assuming it makes the 120mi trip home!
CptTripps
post Aug 29 2013, 11:12 AM
:: Punch and Pie ::
So I'm stocking up parts already. Trying to use 914World members wherever possible.
1975 914 w/V8 (xsJerry)
3.5" 911 Struts (sebring66)
Boxster Brake Conversion (a914guy)
986 Brake Calipers (eBay)
Pontiac Solstice Rear-View Mirrors (eBay)
17" Boxster Rims (Cleveland Craigslist)
Steel Flares (dr914)
Fiberglass Rockers (dr914)
10-Piece Chassis Stiffening Kit (dr914)
Still waiting on a set of rotors to materialize that will work.
My assistant's boyfriend wrecked his 03 WRX, so I'm going to grab that motor/tranny and some other assorted parts in a few weeks. I'm not going to tackle the engine swap until the snow flies. At that point, I'll sell off the Renegade V8/901 combo or perhaps just sell the engine locally. (I may be able to just trade it to her BF for the Subaru engine.)
Here we go!
CptTripps
post Aug 30 2013, 06:47 AM
:: Punch and Pie ::
Parts are showing up every day...the car is still stuck in California. (IMG:style_emoticons/default/huh.gif)
Picked up rear-view mirrors for a Pontiac Solstice.
$85 Shipped...brand-new. (IMG:style_emoticons/default/aktion035.gif)
I'll need to modify them a little bit, but this should be a great starting point for a modern looking mirror.
Make sure you get the "Manual" version and not the electronic. They're the same price (imagine that) but these move a lot easier. (Guy down the street has one, and I tried moving the mirrors manually and they "clicked" across the servos.)
CptTripps
post Aug 30 2013, 06:49 AM
:: Punch and Pie ::
Brakes arrived!
...and they're wrong. (IMG:style_emoticons/default/dry.gif)
I open box: Sweet!
I read the part numbers: Shit!
Here's what they sent me.
996.352.422 (RR)
996.352.422 (RR)
986.351.422 (RF)
996.352.421 (LR)
So I got 3 rears and a front. Doh!
Quick email to the seller, and they're going to send me the correct calipers, and take these back. Once I get them, I'll send the calipers and a few other pieces-parts off for powder coating.
CptTripps
post Aug 30 2013, 06:53 AM
:: Punch and Pie ::
Rims I picked up locally off of Craigslist.
$500 for all 4, but they have winter rubber right now, so that'll be fine for placement and the rest of this summer.
Front: 17x7.5 - 205/50-17
Rear: 17x9 - 255/40-17
Thinking about powder-coating them, but another member (jbyron) suggested I'd give PlasitDip a shot. They came out VERY cool...so I'm going to run them this year to see what it holds up like. Not bad for $5.
uncle smokey
post Aug 30 2013, 09:38 AM
The wheels look great. I am curious to see how they hold up. Is it just the regular rubber coating or is there a different one?
CptTripps
post Aug 30 2013, 07:10 PM
:: Punch and Pie ::
Just the regular PlastiDip Spray you buy from Home Depoti have the Glossifier spray too, and I'll put a coat of that on tomorrow.
My caps came in today...so I sprayed one to see what it looks like.
cwpeden
post Aug 30 2013, 07:12 PM
Great White North, huh?
Region Association: Canada
Have you considered a vinyl wrap? Uniform colour and sheen. Plus some cool colours. That GT looks like vinyl.
CptTripps
post Aug 30 2013, 07:15 PM
:: Punch and Pie ::
QUOTE(cwpeden @ Aug 30 2013, 09:12 PM) *
Funny...I asked that very question a few days ago...and that led me to the dip!
http://www.914world.com/bbs2/index.php?showtopic=218045
I've got 5-6 different colors of Vinyl on the way. I should have them soon so I can start testing both.
CptTripps
post Aug 31 2013, 12:44 PM
:: Punch and Pie ::
Parts fairy showed up today...with a great delivery from the ATL.
Steel Flairs
Rear Chassis Stiffening Kit
GT Rockers
...still don't have the car. (IMG:style_emoticons/default/dry.gif)
11 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
2 Members: porschetub, 76-914
- Lo-Fi Version Time is now: 10th April 2026 - 11:24 PM
