Martini 914 1974, restoration thread |
falcor75 |
Feb 2 2013, 09:09 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Got my first 914 home last monday...barely had time to look at it becuase of work.... was in rougher shape than the pictures I was sent of it before buying it.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.964c2.se-15176-1359817741.1.jpg) Spec's: Front glasfibre hood Rear glasfibre hood Front GF bumper (cracked) Rear GF bumper Rollcage Old five point harnesses, will be discarded. Three point belts will be installed (needed to pass Swedish registration) Rebound adjustable red Koni's front and rear Springs "140 lb Weltmeister" Engine overhauled 2001: "Euro" pistons Camshaft, unknown spec. Overhauled heads with new valves and guides Weltmeister oiltrap Flywheel lightened 2 kg's Frontmount oilcoover External oilfilter etc.... It's a pretty rough looking car but the plan is to get it registered (ex California car, I got it from 914er-teile in Germany) and then tear it to pieces and do it right, find all rust, fix it and have it resprayed. Yes, my projects tend to go overboard.... (IMG:style_emoticons/default/biggrin.gif) The long term plan is to build my own version of a "914 RS" in the same kind of way as the 964 RS was made. Original looks, a little bit lighter, a little more power, a little better brakes and handling. |
billh1963 |
Feb 2 2013, 09:16 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Got my first 914 home last monday...barely had time to look at it becuase of work.... was in rougher shape than the pictures I was sent of it before buying it. They always are! Congratulations on the new purchase (IMG:style_emoticons/default/beer.gif) |
doug_b_928 |
Feb 2 2013, 09:18 AM
Senior Member Group: Members Posts: 689 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Subscribed. Looking forward to watching the resto.
rick 918-S |
Feb 2 2013, 09:22 AM
Hey nice rack! -Celette Group: Members Posts: 20,406 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Looks like a nice start. Love white.
Tom_T |
Feb 2 2013, 11:49 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
(IMG:style_emoticons/default/welcome.png) .... and to the Quest! (IMG:style_emoticons/default/shades.gif)
(IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/driving.gif) |
falcor75 |
Feb 2 2013, 12:16 PM
Thanks (IMG:style_emoticons/default/smile.gif)
Today's mission was to pull the rollbar and 5 point harnesses from the car. Was a bit of a chore getting the rollbar out on my own, had to move around the car and wriggle it up between the sills a few mm's at a time on each side. Tomorrow I'll tackle installing the 3 point belts and do a list of stuff that needs to be fixed to pass the registration check... |
mittelmotor |
Feb 2 2013, 06:29 PM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Nice! the Rivieras look great on a white car.
falcor75 |
Feb 3 2013, 06:33 AM
Finished the seatbeltinstallation today and cleaned up the rear vinyl pad aswell since it was quite nasty. Did some looking around and this is what I've found to fix so far.
* Brake lights doesn't work.... *High beams doesn't work, no click from the relay when I pull on the stalk *Washer bottle non existant, will convert to electric pump system. *Interior light broken *Instrument lights very weak, probably a few dead bulbs *Need both rear rubber grommets that hold the top in the trunk *Left rear wheel hard to turn, probably stuck hand brake... more to come as I find it... (IMG:style_emoticons/default/rolleyes.gif) |
falcor75 |
doublepost....
FourBlades |
Feb 3 2013, 06:52 AM
From Wreck to Rockin Group: Members Posts: 2,054 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
JawjaPorsche |
Feb 3 2013, 07:59 AM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Nice Score! Welcome to our Madness! (IMG:style_emoticons/default/beerchug.gif)
Cairo94507 |
Feb 3 2013, 08:09 AM
Michael Group: Members Posts: 9,703 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
You seem to be approaching it in a nice systematic order. I love white on 914's. Good luck and keep posting.
falcor75 |
Mar 3 2013, 02:32 PM
Ok, I need to be educated on the warmup and idle behaviour of a Djet 2.0
Mine starts up easily with a little throttle help the first few seconds when cold. Idles around 1000-1200 and after half a minute or so the idle raises to about 2500-3000 and stays there, after 5-10 minutes it slowly decreses down to around 1500. From what I've read the rising idle untill warm is normal but a but too high. I couldn't find any vacuum leaks with starterfluid but need to try it again since I only had a few squirts left in the can. |
falcor75 |
Nov 25 2013, 12:23 AM
Ok, it's been awhile since I wrote here. (IMG:style_emoticons/default/WTF.gif)
The car passed the Swedish registration after alot of hassles this spring, the "ex-California, export to Germany and then imported to Sweden" caused some greif and worries but it sorted itself out in the end thanks to help from the Swedish VW/Porsche group that helped with some brake certification documents. (IMG:style_emoticons/default/pray.gif) Wasting no time me and a friend tore into the car, cataloging nuts and bolts and small parts in labeled zipbags and soon we had a bare shell. The shell has been one trip to the bodyshop for some straightening och rust repair, I also had them weld in a rear suspension reinforcement kit from Tangerine. Currently I'm working on the surface rust in the center tunnel and working my way outwards from there. (IMG:http://www.914world.com/bbs2/uploads_offsite/matsgarage.com-15176-1385360592.1.JPG) |
arkitect |
Nov 25 2013, 06:10 AM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
MMW |
Nov 25 2013, 06:59 AM
Member Group: Members Posts: 152 Joined: 6-October 13 From: Northern NJ Member No.: 16,477 Region Association: North East States |
Looks like you are doing a nice job. Can you post some pics of your car dolly? It looks interesting as I haven't seen one like it before.
cary |
Nov 25 2013, 07:28 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
naro914 |
Nov 25 2013, 07:37 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
I was actually marveling how his garage in Sweden doing a restoration project looks just like all the garages here in the States doing a restoration project...some things don't change anywhere in the world you are!
Looks great! |
saigon71 |
Nov 25 2013, 07:50 AM
Senior Member Group: Members Posts: 1,995 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Looks like you are making some fine progress! (IMG:style_emoticons/default/beerchug.gif)
Take your time and do it right the first time, then just (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) |
rick 918-S |
Nov 25 2013, 08:31 AM
I like that car dolly!
Lo-Fi Version | Time is now: 19th April 2024 - 02:42 PM |
