| 914ltd |
Oct 6 2011, 06:34 AM
Member ![]() ![]() Group: Members Posts: 247 Joined: 18-April 03 From: Peoria, IL Member No.: 581 Region Association: None
I posted this previously, heating season is here again. These are big cracks, a tiny one you would not be able to hear would still be dangerous. These are not accident damaged. If you have a set on your car, grab the carbon monoxide detector from home and take a ride with the heat on and windows rolled up. There is a detector used in small aircraft also available. The last photo is how we now test for leaks using air pressure. Brad
This post is still relevant today some 15 years since I first posted it. A large number of these early SSI's are still around in parts stashes and yet to be restored 914's. The currently available heats are most likely safe. I have not found anything similar in a stock, even rusty heat exchanger. STAY SAFE! Brad Mayeur Attached image(s)
Oct 6 2011, 06:43 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,928 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
So just the shell is stainless?
| rick 918-S |
Oct 6 2011, 06:50 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,353 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Thanks Brad! I have seen a set like that. Just because you have SS exhaust does mean they are not fatigued.
| jimkelly |
Oct 6 2011, 06:51 AM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i believe the pipes are stainless too - a magnet should not stick - some though do have steel muffler flanges.
i assume high heat is hard on stainless ?? brad - how frequent would you say this is ?? would capping one end off and filling them with water be a good enough test ?? jim -- |
| wingnut86 |
Oct 6 2011, 07:27 AM
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Just assuming here, but is the washer/rubber dongle for a compression seal fitting for the opposite end of the hookah? If so, where did you source the rubber puck? Also, what's the max pressure for the volume and an acceptable drop over "?" Time?
Sorry for the soliloquee(sp)... (IMG:style_emoticons/default/blink.gif) Dave |
| rick 918-S |
Oct 6 2011, 07:40 AM
Just assuming here, but is the washer/rubber dongle for a compression seal fitting for the opposite end of the hookah? If so, where did you source the rubber puck? Also, what's the max pressure for the volume and an acceptable drop over "?" Time? Sorry for the soliloquee(sp)... (IMG:style_emoticons/default/blink.gif) Dave Those are available in the hardware store I think. Tighten the nut and they squish and expand. Also automotive emergency freeze plugs. |
| VRROOMM1 |
Oct 6 2011, 07:42 AM
Member ![]() ![]() Group: Members Posts: 117 Joined: 15-July 08 From: mt. dora fl Member No.: 9,302 Region Association: South East States |
Just assuming here, but is the washer/rubber dongle for a compression seal fitting for the opposite end of the hookah? If so, where did you source the rubber puck? Also, what's the max pressure for the volume and an acceptable drop over "?" Time? Sorry for the soliloquee(sp)... (IMG:style_emoticons/default/blink.gif) |
| 76-914 |
Oct 6 2011, 07:47 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,981 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Just assuming here, but is the washer/rubber dongle for a compression seal fitting for the opposite end of the hookah? If so, where did you source the rubber puck? Also, what's the max pressure for the volume and an acceptable drop over "?" Time? Sorry for the soliloquee(sp)... (IMG:style_emoticons/default/blink.gif) Dave Or in the plumbing section. aka wing nut test plug. These are great detectors and affordable. They start at $3-$4. http://www.aircraftspruce.com/search/search.php |
| wingnut86 |
Oct 6 2011, 07:52 AM
Great responses. All noted in my broken Carolina Anglish...
Thoughts on the 2nd part of the question? I can look in the Factory manual when I get home if you guys think it's in there... |
| tradisrad |
Oct 6 2011, 07:53 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I've seen a cracked one.
| dlee6204 |
Oct 6 2011, 08:16 AM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
This is a great thing to check. Thanks for posting this. (IMG:style_emoticons/default/thumb3d.gif)
| 914ltd |
Oct 6 2011, 09:04 AM
| SLITS |
Oct 6 2011, 09:14 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
So just the shell is stainless? Jim The whole heat exchanger is stainless except the earlier muffler flanges. The pipes are a magnetic stainless (304?) Brad, 304 would be non-magnetic as I remember. 400 or 500 series would be magnetic (more iron, less nickel - from my days in the restaurant equipment industry). |
| 914ltd |
Oct 6 2011, 09:22 AM
i believe the pipes are stainless too - a magnet should not stick - some though do have steel muffler flanges. i assume high heat is hard on stainless ?? brad - how frequent would you say this is ?? would capping one end off and filling them with water be a good enough test ?? jim -- SSI says the heat and salt caused this but I have heard from owners in no salt areas with this problem. Frequency? I pitched a couple before I cut these open but I have probably sold 50 used pair since they became available in the 70's. Any method including water should work but there is a possibility of a tiny crack not showing with air or water. I don't have set test procedure for the air pressure, we use 10 psi, the time period until the air bleeds off mostly depends how good the test plugs work. Be careful not to aim the expanding rubber plug (hardware store item) at anything during test! Brad |
| jaxdream |
Oct 6 2011, 09:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
One way of using this method is to hold each pluged end in a bucket or tub of water to see if the seal is leaking thereby eliminating the question if the pressure drops is it coming out of the pluged ends , kinda like the old tire puncture location test. This should be very doable for folks wanting too check their heat exchangers , great idea that I will do when the time comes to use / not use mine . carbon monoxide= DEATH. Recently some folks in a town north of me died in a RV from a faulty generator exhaust , this happened over night , next morn they were gone , 5 peeps total . Also on another trip to an event where tents were allowed , a fella , his son ,and his son's friend didn't wake the next morn because of using equipment inside the tent , dew sealed the tent so it couldn't breath and they were gone also.
Thanks Brad for posting this procedure as it may help a lot of guys as to the usability of thier heat exchangers. (IMG:style_emoticons/default/smilie_pokal.gif) Jack |
| avidfanjpl |
Oct 6 2011, 12:11 PM
914 Hemophiliac ![]() ![]() ![]() Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
Sounds like we should see if someone is willing to make new SSHE's even though the price would be PRICEY.
Racer Chris at Tangerine? ALL Stainless? Something to consider. Life is good, but CO is bad. I don't use heat, but this scared me good. I checked mine when off the car last spring by filling them up with water and looking for leaks pipe by pipe, but it was all good, still, no fun to gas oneself unknowingly. John |
| flipb |
Oct 6 2011, 12:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,899 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region
I've previously gotten oil (from a leak) into the SSHE's. As it's burned off, I've seen smoke through the ventilation system occasionally.
The oil leak was fixed about 300 miles ago - I think/hope - with new pushrod tube seals. If I drive around with my heat on and a CO detector, will it go off due to the remaining oil residue? Or will it actually tell me whether my pipes are leaking? |
| GeorgeRud |
Oct 6 2011, 01:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
As these cars age, things do wear out. Even things you think would last forever.
Probably time to get a simple carbon monoxide detector - this stuff can kill you very easily. Thanks for posting this important information, Brad |
| RFoulds |
Oct 6 2011, 02:00 PM
914Rennsport ![]() ![]() ![]() Group: Members Posts: 871 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region
if you dont need the heat, simply remove the hose from heat exchange to flap box, and manually push the flap all the way closed. Or, remove the flap box too, and put a cover plate over the heat/defrost opening. No more worries.
However, if you need the heat. Move.. |
| ConeDodger |
Oct 6 2011, 02:33 PM
Apex killer! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,609 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Rocky Mountains
Some where all stainless others were not. I recall when I sold a set of brand new in box SSI heat exchangers, the buyer wanted me to check the flange with a magnet. They were all stainless but another set I had were not.
Lo-Fi Version | Time is now: 12th October 2026 - 10:50 PM |
